Thread: Deck lid letters
    Jul 2011
    Brentwood TN
    Deck lid letters
    Have a question about the removal of the deck lid letters.
    My car is an original paint car; paint is still in excellent condition. The letters have never been off the car.
    I am going to have the car professionally polished & detailed in a few days and thought about removing the letters on the rear deck lid prior to the polishing.
    Two questions.
    Is the removal and reinstallation of the letters much of a chore? The device on the inside of the deck lid that holds the letters on looks to be about a 8mm nut, but I don't think it is screwed on. Maybe the nut is simply popped or pushed on?
    Curious to hear thoughts or feedback. Would you leave the letters on (less risk of some unforseen problem removing & putting them back on??) or would you remove them prior to the detailing?
    Feedback is appreciated.
    Jul 2006
    Corvallis, OR
    Detail around them. Too much could go wrong removing them. The nuts and legs on the letters wear out the more you screw and unscrew them. You could pull up or chip the paint removing them.
    72S, 72T now ST
    You haven't said what year your car is. If it's an original '71 the letters should be secured by a unique round black rubber fastener that is actually a round speed nut sandwiched between two layers of rubber. If the letters are secured by a stamped 8mm hex speed nut with a rubber washer backing they have already been off and someone replaced the original round rubber fasteners with the hex dodads. As above, the studs on the letters become worn if taken off too often. Don't know when the original wierd round rubber fasteners disappeared, but they were definately on '69-'71s....actually '65-'67 or so had another variant of the rubber fastener that was harder rubber and conical in shape....you can see them commonly securing the dash fascia as they were not removed and lost as often as the crest and lid letter fasteners. Someone chime in here...not sure what was used on '72 on.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Jan 2004
    Fullerton, CA
    Detail around. Don't eff with those emblems unless you do a complete repaint.
    Jul 2011
    Brentwood TN
    My car is a 1973 model.
  1. FS-PORSCHE early letters for deck lid
    Last Post: 04-23-2012, 03:56 AM
  2. FS: gold deck lid letters
    By John79sc in forum For Sale: 911 Parts
    Last Post: 09-12-2010, 09:34 AM
  3. FS rear deck letters and emblems
    Last Post: 08-22-2009, 09:54 PM
  4. Deck lid letters ? NOA ?
    By Greg D. in forum General Info
    Last Post: 07-08-2008, 09:10 AM
  5. Rear deck lid P O R S C H E letters
    By mwalker09 in forum Technical Info
    Last Post: 07-26-2001, 10:41 AM
