Results 1 to 8 of 8
Thread: Question: how do you convert a 911 clock to plug into a 110 v socket?
    Senior Member Bavaria911's Avatar
    Dec 2012
    Fort Meade, MD
    Team,
    I would like to use a 911 gauge clock as a clock in my office. Has anyone converted one, if so - what kind of converter did you use and how did it wire up to the 110 v plug?
    Vr,
    Scott
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Scott,
    I did this with a green gauge 912 clock for my son's bedside locker. and used an AA battery powered quartz clock inside the casing. Mounted the original "hands" from the clock on the spindle. Not as flash as 110V but certainly easier.
    Good luck! Gary
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Dec 2012
    Fort Meade, MD
    Gary,
    Thanks, but I am looking to keep the clock intact and just using 110 voltage.
    Oct 2008
    Burford, ON, Canada
    Just get a "wall wart" 110 VAC to 12VDC plug in adapter. If need be, cut the end off of the lead, check the polarity of the wires with a voltmeter, then attach the leads to the clock. Be sure the output is DC, and I would guess that a current capacity of 500 mA would be the minimum. If you know the current requirement of the clock, then use at least that value. As I understand the 911 clock, it has an electric wind feature which means the current draw is very small except when winding.
    Dec 2012
    Fort Meade, MD
    Dave,
    Thanks - I am not up to speed with the conversion of AC to DC.
    I have a 911 clock from an early 1980s and want to mount to a frame as a plug in 110v clock for the office.
    I found a wall wart on the Sparkfun.com website and they sell two models, one for a 9vDC 650mA and the other is. 12vDC 600mA converter.
    Which one is best without burning up the clock?
    Vr,
    Scott
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Bavaria911 View Post
    Dave,
    Vr,
    Scott
    the clock doesn't care what amperage it gets as long as it is 12V. A simple 110Ac to 12vDC convertor is all that is required, as already stated. Those convertors usually have a cigarette lighter receptacle on the 12V end. Just cut that off and wire the clock to the two wires coming from the adaptor.
    Ciao
    Jim
    Oct 2008
    Burford, ON, Canada
    That is not quite true Jim, I work in electronic all day long, and need to be very careful to match both voltage and current. Consider as an example a 12V battery for an emergency light, it has the required voltage, but not the capacity to spin a starter motor.
    Short of measuring the current draw of the clock which is the course I would take, I would suggest that the 12 Volt 600mA adapter would be the logical choice.
    Dec 2012
    Fort Meade, MD
    Dave,
    Thank you.
  1. FS- NOS Joseph Pollak Intercom Dash Socket and Plug
    By advtracing in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 01-30-2012, 10:28 AM
  2. Early Spark Plug Socket
    By mrg3.6 in forum Technical Info
    Last Post: 08-24-2011, 04:00 AM
  3. WTB: Spark plug socket & Allen wrench- 1971 vintage
    By Zedone in forum For Sale: 911 Parts
    Last Post: 01-26-2009, 06:57 AM
  4. WTB: Clock delete plug.
    By Macroni in forum For Sale: 911 Parts
    Last Post: 06-24-2008, 08:34 AM
  5. Spark plug socket...tool junkie alert!
    By pwd72s in forum General Info
    Last Post: 01-29-2004, 10:35 AM
