Results 1 to 7 of 7
Thread: Leaky Oil Tubes
    Jul 2010
    Fort Worth, TX
    Leaky Oil Tubes
    In awakening my '71 911S Targa from a way-to-long sleep, I am noticing that I am getting some small leaks from the oil tubes (the o-ring seals have probably dried out). Other than the smell of burned oil as it hits the heat exchangers, should I be fearful that the engine is about to catch fire? Is there any "magic" additive that might help lubricate and swell the o-ring seals? Or is it OK to just drive it a bit to warm everything up a bunch and see if the drips stop on their own? Or just bite the bullet and replace the tubes? Experience from those of you that might have had this happen is most welcome -- thanks,
    Bob
    My oil tubes were in the same condition after my 2.2T came last year. I pulled the exhaust off, changed the tubes using the collapsable ones. The old oil was wiped off the heat exchangers as best I could. It was a little smokey and smelly for a while, but seem to be OK for now.
    Jul 2010
    Fort Worth, TX
    Thanks for getting back. Looks as if you bite the bullet on replacing the tubes. How long did you drive your car before the replacement? Any problems if you did drive the car?
    Bob
    sometimes you can seat the return tube seals better by turning the tube either by hand or carefully with pliers.
    Jul 2010
    Fort Worth, TX
    66S -
    Thanks for the suggestion, I will give it a try.
    Bob
    Drive the car a while, it might seal up. It's not a big job to change out the tubes anyway.
    Jul 2010
    Fort Worth, TX
    David -
    Thanks for getting back to me -- sounds as if you might have had experience driving with small leaks from your tubes? I will give it a go to put some miles on the car, checking fairly frequently to make sure the leaks are very minor.
    Bob
  1. Ol' Leaky is now just Ol' Drippy
    By 68911USA in forum Technical Info
    Last Post: 08-31-2009, 10:50 AM
  2. WTB oil tubes
    By andrea70 in forum For Sale: 911 Parts
    Last Post: 05-22-2009, 06:33 AM
  3. leaky solex carb
    By vintage83 in forum Technical Info
    Last Post: 06-15-2008, 05:52 AM
  4. Inner tubes
    By Stephen T in forum Technical Info
    Last Post: 02-18-2007, 03:22 PM
  5. Tired of that leaky sump plate
    By Henry Schmidt in forum General Info
    Last Post: 04-22-2006, 07:59 PM
