Thread: Distributor curve for 1963 356 Carrera 2
    Jan 2006
    Zurich/Switzerland
    Gentlemen,
    Can someone point me in the right direction for the correct distributor advance curve for the distributors of my 356 Carrera 2? I have the shop manuals etc but can't find more information than "28° max advance"..... That's fine but I need to rebuild my distributors to the right specs. The engine has been professionally rebuilt but then someone wanted to save the huge money the real distributors (or even good copies) cost. Understandable but the curves are very likely wrong.
    A very good Porsche guy suggested that the curves of a 906 could work well. Any information around on their advance curves?
    Thanks a lot!
    Cheers,
    Mike
    Mike, member #841
    Jan 2006
    Zurich/Switzerland
    Still searching, I want to get these distributors done right. I can't imagine that it's so hard, someone certainly has this information or a friend has it etc. I'd really appreciate your help with this and I'd be happy to send you a little gift from Switzerland as my "token of appreciation".
    Thanks guys!
    Cheers,
    Mike
    Mike, member #841
    Paid Member # 1991
    Apr 2010
    Seattle, WA
    I know a mechanic who is one of the few in my region qualified to rebuild these engines, so he might be able to help you. Although he probably wouldn't mind the free press, I hesitate to blast his name on the Internet. PM me and I will give you contact information.
    Regards,
    - MR
    Junior Member
    Feb 2011
    SAN DIEGO
    Hi Mike
    advance degrees10.0-12.5
    5 deg change 375-550
    10 deg 950-1175
    max 1200-1400
    dwell angle 60-65
    i only use 24-26 total advance
    email me if you have any other questions
    cheers
    jacques
    I knew you could answer that one Jacques!
    Erich
    Early 911S Registry #263
    Jan 2006
    Zurich/Switzerland
    Thanks a lot Jacques and MR, I really appreciate it!
    Mike, member #841
  1. Distributor curve for 1963 356 Carrera 2
    By mike66 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 06-26-2013, 07:27 AM
  2. Distributor with 3.2 advance curve?
    By Christian Guthrie in forum Technical Info
    Last Post: 11-27-2011, 09:40 AM
  3. distributor curve
    By 356robo in forum Technical Info
    Last Post: 09-27-2008, 06:23 PM
  4. 1963 Carrera 2
    By 72targa in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 07-19-2008, 07:34 AM
  5. '67 S distributor advance curve
    By aj748 in forum Technical Info
    Last Post: 04-30-2003, 03:33 PM
