Results 1 to 10 of 10
Thread: Looking for info on 69 Sportomatic electrical wiring.
    Feb 2012
    Kolham, Groningen, The Netherlands.
    I'm working on a new wire harness for a 1969 911 Sportomatic.
    Besides the normal harness its not fully clear which additional wiring is required for the Sportomatic gearbox.
    Does anyone have more information on that ? ( maybe picture's / diagram's etc)
    Would like to know wire colors, thickness, locations.
    Any help is very much appreciated !
    Best regards from Holland.
    Gerard.
    Jul 2008
    South Florida
    Sadly, the sportomatic.org site is gone. A shame since all the sporto specific material isn't available online anywhere else.
    This has what you need, but at 25MB takes a bit to download.
    http://www.renntech.info/SharedData/...%20Systeem.pdf
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Aug 2005
    Bucks Co., PA, USA
    Quote Originally Posted by Bullethead View Post
    http://www.renntech.info/SharedData/...ch Systeem.pdf
    Really? That's unfortunate. I think Phil (the most recent site host, after Patrick Wheeler) is still active on the bird; I'll have to try to contact him.
    ESR #1474
    Feb 2012
    Thank you guys,already found something about a site called sportomatic.org but couldn't find it, now i understand why.
    Port Macquarie, Australia
    I wish I had known. I just rewired my 69 former sporto and threw out the harnesses
    1. From memory there is the neutral cut-off switch which ensures you can't start the car unless the gearbox is in neutral - the wires run from the four terminal switch on the gearbox to the starter solenoid and are encorporated in the starter harness. I think they are a combination of reds and yellows (as per the other starter wires running from the ignition).
    2. The wire running from the micro switch on the shifter back to the solenoid that activates the vacuum valve on the engine (brown and white). It runs through the tunnel. Confusingly there is another brown and white wire in the same area running forward, that is for the handbrake dash light. From memory, the solenoid wire is part of the left most round harness terminal located in the engine bay (the round ones up on the cross-member in front of the engine).
    The old 911 Haynes Manual has a short section on the sportomatic and may have a suitable wiring diagram to help.
    Hope that's some help.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Aug 2005
    Bucks Co., PA, USA
    Quote Originally Posted by Fishcop View Post
    I have one of those handy. I could possibly scan and e-mail to the OP if s/he desires.
    ESR #1474
    All the sportomatic wiring diagrams are in the supplements of the first version shop manual. If you can't locate them locally I can copy and send them to you.
    May 2011
    Chelsea, Québec
    I could scan and email too if required... scan would be in color if that helps
    Member #1616
    Aug 2007
    Phila Pa. area
    Wiring Harness
    I have the engine wiring harness for a Sporto. Do not know what year. It has the trans, starter, alternater, sporto valve wiring, with the plastic T connector and the multiple plug wires. The plastic plug is broken but the wire ends are all there, no wires are cut. $200.00 OBO, plus ship and Pay Pal. Can send pictures if interested?
    Mike Curnow
    Mike
    Feb 2012
    Hi Mike, will send you a PM.
    If anyone can send me a copy of the diagram of the Haynes that would be great !
  1. 68 Sportomatic wiring diagram
    By merbesfield in forum Technical Info
    Last Post: 08-01-2012, 04:46 PM
  2. FS: Early 911 Color-coded Electrical Wiring Diagram!
    By derwhite in forum For Sale: 911 Parts
    Last Post: 08-21-2010, 09:01 AM
  3. FS: Engine Wiring Harness for Sportomatic
    Last Post: 05-26-2008, 01:57 PM
  4. Early 911 Factory Color Coded Electrical Wiring Diagram
    Last Post: 03-20-2006, 07:29 PM
  5. Early 911/911S Color Electrical Wiring Diagrams
    By derwhite in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 02-19-2006, 12:28 PM
Tags for this Thread
