Results 1 to 8 of 8
Thread: Finally
    Dec 2008
    Woodland Hills, CA
    Finally
    Just finished my motor...completed rebuilding and mounting the carbs today. Working 6 days a week leaves little time to move my project forward. I've been trying to do as much as I can myself. Getting closer though...Matching numbers 68 911 Normal aluminum case motor with my own personal touches...2.2 "E" PCs, Dougherty DC-30 S Mod cams and more...I went thru the Webers myself. I had never even pulled a 911 motor before. After 4 years I'm hoping to have this baby running by the end of next month...fingers crossed...
    Senior Member Christian Guthrie's Avatar
    Jun 2011
    Arizona
    Looking good, congrats! What type of muffler are you using?
    Jul 2009
    Hamilton, New Zealand
    Looks fantastic!
    Did you do your fan yourself or have someone restore it for you?
    Sanitary!
    What did you choose for tensioners?
    Tom
    Early S Registry #235
    rgruppe #111
    Looks good. Congratulations on the progress...
    -Marco
    TLG Auto: Website
    Dec 2008
    Woodland Hills, CA
    Thanks for the compliments.
    The Muffler is a stainless M&K that I purchases slightly used from Dave at TRE. Still pretty expensive.
    The fan I disassembled, cleaned and had the housing and fan media blasted...then powder coated and I reassembled it.
    I decided against the Carrera tensioners and I went with the original setup. The new stock tensioners are stronger than the originals. I did some extensive reading on the subject and the Carrera tensioners aren't necessarily a better answer in the early motors. At least that's MHO.
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Nice work, looks great
    Tony
    Nov 2006
    S. F. Bay Area
    Superb details. I've seen several of this guys previous cars and his workmanship is generally flawless. He also incorporates many tasteful personal touches that set his stuff apart.
    Brian
    S Reg #1032
  1. Finally!
    By Jim Breazeale in forum Northern California
    Last Post: 10-30-2013, 04:07 PM
  2. Finally it's in
    By gsjohnson in forum General Info
    Last Post: 08-10-2013, 05:57 PM
  3. Finally!
    By steven0401 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 03-18-2010, 01:27 PM
  4. Finally, something new
    By John Z Goriup in forum Off Topic
    Last Post: 09-10-2009, 12:44 PM
  5. Finally got a 356
    By songhoh in forum Off Topic
    Last Post: 11-10-2006, 06:32 PM
