Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Finally it's in
    Dec 2008
    Woodland Hills, CA
    Finally it's in
    Not bad, I got the motor in, in 45 minutes by myself after the motor being out of the car for the last 3 years. My only concern was the motor losing its balance on the jack and not having an assistance to spot the motor. Otherwise it all went fairly easily for my first time. Thanks to all who gave me advice along the way...
    Bummer. Next time, ask to borrow the ATV lift I bought at Harbor Freight on Victory and Fallbrook! It made balancing the engine a no brainer when I did the 912 engine.
    Dec 2008
    Woodland Hills, CA
    That's funny as I went to Harbor Freight to look at one and considered purchasing it. In the end I couldn't justify the $200 purchase for a one time usage. I wish I had known you had one.
    Oct 2012
    Minneapolis
    congrats on a big little step! not too bad to get them in but it's such a great milestone.
    -Kris Clewell
    Professional photojournalist
    red decklid club member #1
    Nov 2003
    Santa Monica CA
    So to protect the muffler from denting, put the engine on the jack without the muffler on the engine. then all you have to worry about is denting the $1000 heat exchangers if the engine falls off the jack ! Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Nov 2006
    S. F. Bay Area
    Congrats, stud! Looks awesome! When are you going to light the candle??
    Brian
    S Reg #1032
    Dec 2008
    Woodland Hills, CA
    I spent the day installing the axles and getting all the underside things done. I had to remove the left side heat exchanger so I could snug up the long oil line. I had a brain fart (plus I'm a rookie) and didn't realize that I couldn't tighten that fitting with the Heat Exchanger in place. I also worked on leveling the muffler. Oh, I almost forgot, I wedged the hot air hose between the starter and the floor during the install, resulting in me having to lower the engine to dig the hose out. Just stupid things from not knowing...
    I'm hoping to light it off on Sunday...I'm pretty motivated now...
    Feb 2003
    Los Angeles
    Congratulations. The engine looks nicely detailed.
    Bert Jayasekera
    1970 911T - Tangerine Orange
    Early 911S Registry #494
    R Gruppe #167
    Congrats G
    A few tips
    That bracket for the fuel pump is used with the Hardi pumps. The Bendix mount flat to the electrical console with a pair of rubber standoffs with a ground strap sandwiched between the pump and the rubber that connects to the ground stud just forward of there. This will relax the bend on your fuel hose from the body and show off that nice sticker!
    Dec 2008
    Woodland Hills, CA
    Hey thanks for the tip. That was how it was, with a different generic electric fuel pump when I got the car. What you say makes perfect sense now. Thank you.
  1. Finally!
    By Jim Breazeale in forum Northern California
    Last Post: 10-30-2013, 04:07 PM
  2. Finally!
    By steven0401 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 03-18-2010, 01:27 PM
  3. Finally, something new
    By John Z Goriup in forum Off Topic
    Last Post: 09-10-2009, 12:44 PM
  4. Finally got a 356
    By songhoh in forum Off Topic
    Last Post: 11-10-2006, 06:32 PM
  5. My MFI is finally in my '69S!!!
    By kenikh in forum General Info
    Last Post: 07-18-2005, 11:36 AM
