Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Finally it's in
  1. #21
    How many wires do you have going to the +terminal of your coil in that picture of it.
  2. #22
    Dec 2008
    Woodland Hills, CA
    There are 2 wires connected to the positive side of the coil. One is the orange wire from the MSD unit. The other is the black wire that formally went to the Ballast resister and now runs directly to the starter relay. Additional that black wire has a splice of another wire that connects to the factory plastic covered power supply red wire. Does that make sense? I really appreciate your help Ed.
  3. #23
    Quote Originally Posted by gsjohnson View Post
    You need to have only the orange wire + and the black wire - from the MSD box going to the coil. Try this and let us know what happens.
    Mike Kuhn
    Mayo Performance
  4. #24
    Here is a link to the MSD forum regarding wiring a '66 911. I have a '68 and used this with correct results. http://www.msdignition.com/forum/sho...hlight=porsche
    Mike Kuhn
    Mayo Performance
  5. #25
    ...and here are the installation instructions from the MSD website. http://www.msdignition.com/Products/...n_Control.aspx
    Mike Kuhn
    Mayo Performance
  6. #26
    Dec 2008
    Woodland Hills, CA
    Ok I'm working on that...I hope I didn't damage the Tach. I have installed a new set of points as well. I realize that it is only a trigger device now. Is the point gap critical?
  7. #27
    Dec 2008
    Woodland Hills, CA
    Ok I've got spark now. Removing all the coil connections except the two MSD leads worked. Thank you Ed and Mike.
  1. Finally!
    By Jim Breazeale in forum Northern California
    Last Post: 10-30-2013, 04:07 PM
  2. Finally!
    By steven0401 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 03-18-2010, 01:27 PM
  3. Finally, something new
    By John Z Goriup in forum Off Topic
    Last Post: 09-10-2009, 12:44 PM
  4. Finally got a 356
    By songhoh in forum Off Topic
    Last Post: 11-10-2006, 06:32 PM
  5. My MFI is finally in my '69S!!!
    By kenikh in forum General Info
    Last Post: 07-18-2005, 11:36 AM
