Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 65
Thread: Found 1968 "S" - need some advise
  1. #21
    This type of clip that secures the brake line, I beleive is found on the early models (???)
  2. #22
    Quote Originally Posted by AlexJ View Post
    I have some more details from today...
    I have been disassembling the front suspension.
    Koni shocks?
    Attachment 259690
    Font calipers look Early type, right?
    Attachment 259692
    Attachment 259691
    These are not SWB front struts
    Are the rotors ventilated? Because the calipers look to be iron and therefore not (later) S (only SWB S calipers were iron?).
    Richard
  3. #23
    probably A calipers, cast iron used after aluminum S calipers
  4. #24
    Oct 2008
    Burford, ON, Canada
    The struts will say Koni on them if that is what they are; also a part # and a date. There are two kinds, depending on how the ball joint was fastened; the bottom end was split to allow a clamp bolt to hold the early joint, or not split for the wedge pin on the later joint. You need to know to be able to obtain the correct ball joint and fastener. Those are the A calipers, so the strut is probably Koni with the 3.5" caliper mount; a good score. So it appears that the suspension was upgraded to the long wheel base version.
  5. #25
    Looks like it has LWB aluminum rear trailing arms, SWB style wiring harness at the rear, modified wiring harness in trunk area, rocker sills have the SWB heater outlets, struts appear to be the wedge type, brake line clips are style used from 356, 914, and all 911's. Looks like front strut towers have welded on ears for strut brace. Looks like a solid tub.
  6. #26
    I think you are right davep and edmayo.
    Take a look at these pictures I just took, from the front suspension:
  7. #27
    Dec 2003
    West Los Angeles
    Over on Pelican, there's a set of 15 X 5.5 Fuchs date stamped 2/68. Maybe you want to scoop those up?
    techweenie.com
  8. #28
    Thanks for the suggestion.
    I will check it out.
    I wonder if I will have the time ($$$) to buy them...
  9. #29
    Banned
    Nov 2004
    Scottsdale, AZ
    I almost peed my pants after reading Ed's comment "Looks like a solid tub" then 10 seconds later seeing the pic of the femur bone still attached to the cross member!
    Hilarious!
    Alex, good luck with the project.
  10. #30
    Hilarious!
    Do you think it is repairable?
    What do you think is a possible cause for that to happen?
    Would this problem be enough to make you quit this project?
    Sorry for so many questions but I am getting really involved on this...
  1. FS: "REPA" seat belt dated label. 1968- 1973
    By stretch in forum For Sale: 911 Parts
    Last Post: 03-11-2024, 11:16 PM
  4. found a "S" case
    By 9146racing in forum General Info
    Last Post: 04-12-2010, 05:52 AM
  5. Found - "Son of Sam" 67S Survivor
    By MarkP in forum General Info
    Last Post: 05-10-2005, 11:29 PM
