Results 1 to 10 of 13
Thread: Info on outside thermometer gauge
    Oct 2011
    California
    On a 68L US car what would the outside thermometer gauge look like?
    Car has white gauges of course. Would the VDO outside thermometer gauge have green numerics?
    I have not seen one with white numerics. COA says car had one but it is missing.
    Thanks.
    Oct 2011
    California
    Pics would be helpful.
    Member #2634 Mac911's Avatar
    Nov 2011
    Murrieta
    Name:  Thermometer In C.jpg
Size:  103.8 KBName:  Thermometer in F.jpg
Size:  99.9 KBrmfent:
    Here's the little I know or recall on the exterior thermometers:
    The exterior only thermometer was first introduced in the 911/912 Accessory Catalog as # 9168. It was for an outside only 60mm gauge in a Fahrenheit single needle configuration. Part number 644.741.601.07
    Item # 9169 part number 644.731.601.06 was for the exterior only thermometer 60mm in Celsius. The Fahrenheit one was made for the U.S. market. They are not as rare as the original 356 gauges, but original 911/912 60 mm working gauges are becoming very collectable. Once that gas tip leaks or is broken they cannot be repaired.
    If you want to add a thermometer in your car, It's more cost effective sometimes to get a single needle reproduction available from North Hollywood Speedo that has an electrical sensor tip, or by using an early 911/912 VDO or MotoMeter 60mm gauge.
    I had an original VDO exterior thermometer that I had refaced from C to F to use in my 356 T-6 B but decided not to drill a hole in my dash. I also didn't care to install it in my 73.5 T. It was an original working gas tip one in the original box.
    They jumped on my NOS Motometer outside temp gauge on Pelican because the zeroes had the wrong font, elongated versus round as in this photo.
    what was the year range for the in-dash variety?
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Are these clamps available from a supplier?
    If not I could make some more if there is a need.
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by keith View Post
    I can't find anything on the last year of the thermometer but the first I know of is in the September 1964 356C Accessories Brochure reproduced in Miller & Merritt Porsche: Brochures and Sales Literature--A Source Book, 1948-1965
    • 9167 Outside-Inside thermometer
    • 9168 Outside-Inside thermometer next to the clock in the middle of the instrument panel.
    In the February 1961 356B Accessories Brochure 9168 was the anti-theft gear shift lock.
    The September 1965 [1966 Model Year] 911/912 Accessories Price List shows:
    Bestel l-Nr. Artikel
    Order No. Description DM US $
    9169 Außenthermometer, diameter 60 mm 60 US$15
    644.741.602.06 Outside-thermometer, diameter 60 mm
    9170 1 Satz Außenthermometer-Zeituhr, je 80 mm dia 160 US$40
    902.741.601.00 (nur für 912, wenn die Bestellung im Auftrag vermerkt 1st)
    901.741.702.01 1 set, outside-thermometer and clock, each 3.2" diameter (only for 912, if requested on original order)
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
    66S, the July 66 factory accessory booklet shows a Celsius gauge with round zeros and is what is in my 67S.
    58 speedster
    66 912
    67S
    73S
    97 VW eurovan
    1132 honda snowblower
    member Jackson Hole Ski Club
    I had some of the green faces made with the correct numerals in Celcius to restore some of my gauges. Still have some left
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by uai View Post
    Started off today.
    to be continued
Size:  78.6 KBName:  IMG_2785_k.JPG
  1. Outside Thermometer WANTED
    By Rennman in forum For Sale: 911 Parts
    Last Post: 12-30-2010, 05:40 PM
  2. NOS Outside Thermometer for SWB
    Last Post: 03-27-2010, 04:47 PM
  3. Placement of outside thermometer?
    By FHernand in forum General Info
    Last Post: 02-16-2009, 12:48 PM
  4. Gauge info?
    By Doginu in forum Technical Info
    Last Post: 01-18-2008, 07:32 AM
  5. Outside Thermometer for 67S
    Last Post: 02-28-2007, 01:29 PM
