Results 1 to 10 of 16
Thread: Seat belt options
    Dec 2011
    Victorville CA
    Seat belt options
    I have installed sport seats from Vintage Seats on my 69 coupe. What are my options now for seat belts? I just want to go with a 3 point belt that would mount to the existing pillar mount location but what about the front for the receiver and latch? Has anyone out there who have these seats added have photos and/or ideas? The sliders are Recaro tilt sliders. Thanks
    Dec 2011
    Victorville CA
    Anyone? I've searched and can't locate a thread. I can't drive without belts!
    Sep 2009
    UK
    Bob, do you have a threaded seatbelt mount on the inner sill/ rocker ? If you have no provision to put the receiver on the seat, you can weld a point on the centre tunnel
    Then use an extended webbing to create the receiver. A bit like the Rear seat lapbelts.
    Dave
    Dec 2011
    Victorville CA
    Both the receiver and latch are on my existing stock seats
    #2264 classic's Avatar
    Nov 2004
    Gold Coast.
    Bob,
    Can you post a photo of how you mounted them?
    I've fitted Deser seats which are similar, but I fitted tilt-able frames which have the seat belt mounts fitted to the frame, rather then the seats themselves as per origional.
    Tony
    Dec 2011
    Victorville CA
    Quote Originally Posted by classic View Post
    I stand to be corrected. They are not tilt bases.
    They came with a steel plate that mounts to the existing chassis slider mounts because the new seat and sliders are narrower. I'll post pictures.
    I have a pair of "vintage seats" buckets mounted on sliders. The seats nor the sliders have provision for mounting the seat belt receivers. So, a whole was drilled through the tunnel behind the front seats, and threaded. The receivers are attached to a steel bracket, and the bracket is bolted to the tunnel.
    Cheers!
    Frank Kohnen
    Jupiter, FL USA
    Registry Member #921
    1972 Bahia Red 911 Coupe #9112100390..."Rudy" SOLD
    1967 Savannah Beige VW Beetle Sedan #117364457..."Heidi"...aka "Tinker Toy"
    Dec 2011
    Victorville CA
    Name:  mount plate.jpg
Size:  80.1 KBName:  plate with slider.jpg
Size:  99.0 KBName:  seat.jpg
    Quote Originally Posted by FL-Frank View Post
    Frank, do you have a photo? That makes sounds like it won't be too difficult but I'm confused with what to do on the other side near the door. What seat belts did you use? The original belts. It looks like the door side seat belt piece on my stock seats aren't removable.
    Quote Originally Posted by Bob Harriman View Post
    Your stock seat belt receivers will thread into the two little holes on the tunnel of the bracket - you can see these holes in your photo.
    Just remove the sliders from your stock seats, then remove the receivers, re-install the sliders and install the receivers on your Vintage Seat bracket.
    keith
    '75 RS/RSR-look | '73 CB750 | '70 TD250B
    r gruppe # 436
    Dec 2011
    Victorville CA
    More photos
    Name:  seat anchors.jpg
  1. Replies: 0
    Last Post: 01-06-2014, 04:29 PM
  2. FS: NOS seat belt holder for 3 point seat belt in SWB 1964 - 67
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 11-19-2013, 01:28 PM
  3. WTB: Seat/shoulder belt set for 911- front seat, non retractable.
    By Eminence Gris in forum For Sale: 911 Parts
    Last Post: 09-28-2013, 04:30 PM
  4. Recaro Sport Seat , Seat belt Receiver (1970)
    By TB73 in forum Technical Info
    Last Post: 07-08-2012, 10:24 AM
