Results 1 to 10 of 17
Thread: Resurrecting Pearl; a tale of “Restomodration”
    After sitting under a car cover and up on jack stands for nearly three years it’s time to stop making excuses and resurrect Pearl.
    Before the fun begins a little history;
    ’71 911T 2.2l light ivory/hellelfenbein 115k miles purchased in 2008 from Route 30 Classics in Mosier, OR. My wife took an immediate interest in this car, declared it as her own and named it Pearl. It’s good to have a spouse with interests like this. We drove the car for a couple of years, while making various repairs and upgrades. In the fall of 2010 I decided it was time to replace the oil burning, tired and non numbers matching 2.2l with a low mile hot rod 2.7l that had been found locally. I began the replacement of the engine, then tripped, fell and began the tumble down the slippery slope of Porsche 911 “restomodration”.
    The logic was as follows;
    Since the engine is out for replacement, might as well refresh and upgrade the rear suspension. All of the bits were secured to install ERP poly bronze bushings, adjustable spring plates, hollow torsion bars, new dampers, alloy trailing arms and mono ball pivot bearings.
    Since the engine and rear suspension are out this would be a good time to get rid of those later model rocker panel covers the previous owner had installed. Lets take them off blend the paint and be done with it.
    Since the engine, rear suspension and rocker panels are off we might as well replace the replica fiberglass S front bumper and ducktail with parts that are less attention grabbing and more minimalistic looking.
    Since the engine, rear suspension, rocker panels, bumpers and engine cover are off the car, we might as well do a bare metal repaint of the car, since it’s looking rather tatty and had been re-sprayed two times over the factory coat.
    That’s where my attention, time and money became diverted on various family activities, household projects and business related work.
    Fast forward three years and one day while in the workshop, for no apparent reason, I pulled back Pearl's car cover and started to work on the old girl. My wife noticed this unusual activity in the workshop and said “I’m glad to see you working on Pearl again”. Wow, what a great wife!
    The plan for resurrection is as follows:
    This will not be a factory to the numbers restoration. It’s just not my style or nature to leave things alone and since I’m building this car for me, err I mean for my wife, then that’s the way it’s going to be done.
    Bare metal to the tub repaint in the original light ivory/hellelfenbein. The car weighed 2180 prior to beginning this project and my goal is to be at 1999 or less at the completion of the restomodration. Removal of all unnecessary brackets and bits with the goal of lightness in mind. TRG fiberglass trunk and engine lids.
    All new interior. Rear seat delete, RS carpet, light weight seats, etc.
    All new front and rear suspension. Polybronze busings, Bilstein strut housings, Vonn dampers, hollow T bars, adjustable front and rear anti-roll bars. Replace the front pan due to a shoddy patch job by one of the previous owners.
    Every nut, bolt, cable and hose replaced as well as custom touches as the project progresses.
    Below are a few photos of where this project started, some of the upgrades achieved thus far and where things currently stand. The attached link is a photo gallery of where many more detailed photos will be posted.
    https://www.dropbox.com/sh/wddlv37ukhzi9l4/4Lbb9mPLIP
    I’ll provide updates as progress is made, with hopefully no large gaps in time between those updates.
    The old worn out 2.2 lump with the new 2.7 lump waiting in the wings
    Rear trailing arms completed. Gone are the original steel trailing arms and they will be replaced with '74 alloy arms. Lower shock mounts milled to provide clearance of shock body in upper shock mount point. All parts re-plated, ERP mono ball inner bushings, Wevo E-Z pin bolts, reinforced bearing retention plates.
    911S front calipers and stock rear calipers resorted to perfection by PMB Performance. Stainless steel pistons and Porterfield R4-S pads.
    E brake handle assembly, pedal cluster and heater flapper boxes rebuilt, stripped, powder coated, replated, rebushed, etc
    Steering rack rebuilt. All new boots, bearings, turbo inner rod ends, spherical outer tie rod ends and Rebel Racing bump steer kit.
    May 2011
    Chelsea, Québec
    Looks great and I'm sure you will enjoy the outcome of your labours!
    Member #1616
    Thumbs up
    Look'n good man, great project........
    The wiring harness was removed from the car last week. Some say it’s impossible or very difficult, to me that sounds like a challenge. Yes you can snake this harness from the back of the car, forward through the tunnel and out through the trunk. Some minor disassembly of the engine compartment connector heads were required, but nothing major. Also, the factory plastic sheath was removed in order to slide the harness wires from the right side of the torsion bar tube to the center where there was enough clearance to pull it clear of the torsion bar tube.
    The harness itself is very simple and it’s likely the headlights alone on my daily driver BMW have more wires than the entire 911 harness.
    Made some more progress over the weekend. Removed the front and rear windows, dash and the rest of the interior bits. The good news is no rust in the bottom corners of the either window frames. The back window has a 2 stage defrost element. Top and bottom sets of elements turn on separate from the middle set of elements. I’d like to convert this to a one stage defrost and in doing so eliminate some wires from the wiring harness. Does anyone know if there would be any problems with circuit overload if all 3 elements operate simultaneously from the first position on the defrost switch?
  1. How To - Resurrecting old thread links
    By beh911 in forum Test Area/Help
    Last Post: 03-10-2014, 04:45 PM
  2. An early S pearl from 2006
    By 91133 in forum General Info
    Last Post: 01-22-2014, 08:46 PM
  3. Old ad but worth resurrecting ....
    By nickd in forum Other Porsche Passions
    Last Post: 11-06-2011, 11:47 AM
  4. Earl the Pearl in Print...
    By VIper Green E in forum General Info
    Last Post: 12-27-2007, 04:51 PM
  5. Earl the pearl man of the day.
    Last Post: 02-14-2006, 04:01 PM
