Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 89
Thread: Dual Battery Options
  1. #61
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    In a cold winter I decided to remove the batts and did a nice shortcut with the upper part of the origional 2 pieces strap to one of the + pole.
    So I decided to go this way. No upper parts will hang arround, when removing the batts and the ground with one hand
  2. #62
    Senior Member damsroy's Avatar
    Jun 2007
    Connecticut
    My opinion is that the only answer is the Sonneschein gel type battery, it absolutely mimics the original fit. Expensive,,,but less than new front pans. The cables, brackets, and original rubber positive post protector fit perfectly. Second photo shows how I disguised it to look like OEM battery.
    Thank you Ed. Looks like this is the only way to go if you want to prevent any damage due to leaks.
    Early 911 S Registry member #3308
    911E 1973 - Brownie- 66k original miles - Second owner
    911E 1971 - gold metallic - sold and missed
    912 1966 - sold
  3. #63
    Nov 2003
    Santa Monica CA
    Are those two Sonneschein battery's ? Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
  4. #64
    Apr 2003
    Portland, OR
    Quote Originally Posted by rpc356 View Post
    Can you post photos with them installed? Be interested to see how they look.
    My single battery solution with a Optima.
    Harry
    Member #789
    2009 MB C300
  5. #65
    What's the latest thought on this? I have Interstates and they're toast. Did you ever cut the cases and install the agm's? Does anyone have pics of the miata battery install? I need to do something this week, and I really dont want to re-invent the wheel. I'd like to use agm's but I am concerned about the electrical/ charging requirements vs the old charging system in the 72t.
    Respectfully
    Guy Zindel
  6. #66
    I did 2 Miata batts:
  7. #67
    Atlanta, GA
    David, is that battery supplied by Bosch or a fake sticker? I use the generic Miata AGM batteries produced by East Penn and typically have the model number: 8amu1r
    These are in both my S and RSR rep and work well. I do keep them hooked up to trickle chargers so no drain ever. Work very well.
    Mark Erbesfield
    1973 911S #9113301282
    1957 356A #58648
    1982 Toyota Land Cruiser FJ40
    1977 Toyota Land Cruiser FJ40
    1979 MB 450SL "Dad's old car"
    2019 Cayenne "Wife's car"
  8. #68
    Quote Originally Posted by merbesfield View Post
    Got them at Pep Boys so authentic Bosch
  9. #69
    Dec 2010
    Southold, NY
    What are you guys/girls doing that make batteries such a problem? My '69 Karmann coupe has a Sears Die Hard Group 58 battery that cost $49.99 when I installed it on October 1, 2002. No leakage or other problems during 15 years, 11 months of service. No trickle charger or battery tender ever used. The only modification employed to give this long life is a battery cut-off switch that totally isolates the battery when the car is not in daily use.
  10. #70
    Leakage is usually the main problem, but really, 16 years with the same battery?
    You certainly got your money's worth, I think 6 years is my record.
  1. FS: Early 911 dual battery positive connection cable
    By MountainRoads in forum For Sale: 911 Parts
    Last Post: 03-11-2013, 06:29 AM
  2. WTB - Dual in/Dual Out muffler...
    By Rookie_912 in forum For Sale: 911 Parts
    Last Post: 06-29-2012, 06:59 AM
  3. Are these switches for dual fuel pumps or dual ignition?
    By JPlonghood in forum General Info
    Last Post: 10-08-2009, 07:17 AM
  4. Converting from single battery, back to dual
    By kenikh in forum Technical Info
    Last Post: 06-28-2006, 08:56 PM
  5. 1967 battery options
    By Keith Newby in forum Technical Info
    Last Post: 05-15-2003, 01:26 PM
Tags for this Thread
