Thread: 68 911s MSD Ignition
    Member 11801's Avatar
    Sep 2013
    Ontario, Canada
    Noticed this car is using an MSD ignition, the box mounted on the rear seatback. Should I disconnect it and go back to OEM or some pertronix product. I've had them in domestic applications (mainly from cars that I purchased at auction), but never on imports. The car does take awhile to start with fresh plugs (Bosch platinum w5's)...
    Early S junkie
    72 914/6 2.0
    73 914/4 2.0
    S Registry: #2750
    I use both in different cars. MSD is good but unsightly. you can use points with it so if the MSD fails you can change back to stock ignition. tach output can be a pain.
    in a vintage car the pertronix is nicer because visually it's no different than stock, other than one extra wire. keep a set of points somewhere so you can change back in case of failure.
    for faster starts, dump the platinum and go NGK V-Power.
    hey. just noticed, another hoser. welcome!
    Dec 2008
    Woodland Hills, CA
    +1 on dumping the platinum plugs. Increase your plug gap when running an MSD.
  1. 1970 911S ignition cylinder comes out in my hand!
    By jsavage in forum Technical Info
    Last Post: 07-03-2012, 02:55 PM
  2. 2.7 ignition HELP!
    By weir42 in forum Technical Info
    Last Post: 07-17-2009, 09:29 AM
  3. 1967 911S CORRECT Ignition Lock
    By jwillhoit in forum General Info
    Last Post: 06-06-2009, 02:44 PM
  4. 67 911S ignition upgrades???
    By mjmoran in forum Technical Info
    Last Post: 09-21-2003, 08:44 AM
