Thread: fuel venting lines: normal to sometimes accumulate gas?
    Recently filled up the tank and noticed that the vapor lines had quite a bit of gas in them- is this normal during fill up? Wasn't sure if overflow into these lines is expected/normal...Pic below shows the buildup of fuel in one segment of the lines. Thanks for looking.
    Name:  photo copy 2.jpg
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Aug 2011
    New York
    Fuel does get into the lines, and some will accumulate in the fender tank.
    E Sully
    1973.5 911T
    Apr 2011
    N.Calif., south of SF
    You can check your connections with this ....
    Name:  73 911S Emission fuel vapor recovery 2.jpg
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  1. Euro 70S fuel tank venting
    By rvdv in forum Technical Info
    Last Post: 08-10-2017, 05:49 PM
  2. replacing fuel lines: hoses and metal lines, 1967
    Last Post: 07-10-2013, 05:28 PM
  3. Replies: 3
    Last Post: 03-09-2013, 08:14 AM
  4. 1968 911 Normal fuel pump location
    By JT912 in forum Technical Info
    Last Post: 01-21-2013, 10:13 PM
  5. Correct fuel breather venting for a '69
    By endo911rs in forum Technical Info
    Last Post: 07-06-2009, 02:08 PM
