Thread: MFI Thermostat Rod Extension Dimensions
    I searched for some data on this but could not find anything with my search parameters.
    The rod that extends out of the MFI thermostat from my pump has the following dimensions.
    When cold: Datum to end of rod = 14.3mm
    Free play when cold: Rod can be pulled by hand to 17.1mm (this is not against any spring force what so ever aka. rattles)
    When hot: Datum to end of rod = ~19mm using heat gun.
    Would anyone have any data showing nominal values for these states of the thermostat?
    My car seems to be running rich due to popping in the exhaust. I also checked to see if the thermostat was moving the linkage in the pump far enough which I believe it is.
    Id like to just confirm that my thermostat is operating properly to rule this variable out.
    If anyone has data to share that would be great.
    Thanks in advance.
    1970 911S Targa
    On the road again soon.
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Your measurement for cold seems to be correct. Ranges from 14.25 to 14.75 are normal. The free play when cold is also normal. But your 19mm seems long. The 6mm OD rod itself has a step down to 3.95mm OD at the end where you are taking your measurements. That 3.95mm OD section is 27.50mm long. That step between the two prevents the rod for extending out any feather than 17.50 to 17.75mm. There is also a small cir-clip on the rod just before the step-down. If the cir-clip is missing that might let it stick feather out, but that would cause some problems with the disc measurements. This is the same rod used on the 1970 pump on up. The 69 pump may be a different length, I'll have to check.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Jun 2003
    Toronto
    So if that's the case where rod is coming out to far, wouldn't the engine be running to lean then, I am assuming the further the rod extends the leaner it gets.
    Sep 2006
    Bend, Oregon
    The rod extending out will not make the MFI pump run leaner. The rod when extended can only move the warm up compensator spring guide so far and it bottoms out. The length 19mm on Bob's thermostat tells me there might be a problem inside his thermostat.
    Mark Jung
    MFI Werks
    R Gruppe #686
    Thanks Mark!
    Well I am happy to say that my numbers match yours and that I am not sure how I got 19 for my warm length. The thermostat rod cannot extend any farther then the the spring clip allows which results in the same 17.5-17.75 number you mention. I am not sure how I got a 19mm reading before. Must be getting old eyes already.
    1970 911S Targa
  1. Fs: Steering wheel extension
    By 71-911T in forum For Sale: 911 Parts
    Last Post: 10-25-2011, 04:24 AM
  2. 911 steering hub extension
    By ChristianS in forum Technical Info
    Last Post: 08-18-2010, 11:51 AM
  3. RS Hub Extension
    By kissov356 in forum For Sale: 911 Parts
    Last Post: 05-06-2009, 11:51 AM
  4. RS steering wheel hub extension
    Last Post: 06-22-2007, 05:19 PM
  5. RS Fender Extension Homologation
    Last Post: 04-02-2007, 07:56 PM
