Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: MFI Backfire
  1. #11
    If you have a vacuum retard distributor remove and plug the line and take it for a ride. It may be sticking and not allowing advancement. you idle will come up so you'll have to turn in the air screws about 1/2 turn in.
    If it still backfires It may be too lean which also could cause backfires. Try 2 clicks rich on the main(remember rich is counterclockwise)
  2. #12
    Thanks to all for the helpful suggestions.
  1. exhaust backfire at idle
    By 356robo in forum Technical Info
    Last Post: 07-17-2010, 07:46 AM
  2. Why is my new speed switch causing backfire?
    By jayzoll in forum Technical Info
    Last Post: 05-27-2004, 03:33 PM
  3. Bad Backfire
    By cvfncrew in forum Technical Info
    Last Post: 10-10-2003, 07:12 PM
