Thread: Rocker Deco removal
    Rocker Deco removal
    Looking to remove any restore my Rocker Decos. What is the best way to remove without damaging them?
    Thanks!
    Not sure which year or which trim level you have. I have a '71T with S trim so I had the larger rocker deco strips. For those I just unscrewed all the small Phillips head screws and they just popped right off. Make sure you also get the screws holding the end caps on as well since those secure the ends of the decos at the wheel wells. It's pretty straight forward and shouldn't be a big issue as long as there isn't alot of corrosion on or around the retaining screws. For the smaller deco trim I'm not sure about.
    Stretch
    Aug 2009
    SF Bay Area
    Quote Originally Posted by 50/50 View Post
    Thanks!
    First of all, not all Rocker decos were created equal. No matter what year and model you have, though, you will need to peel the rubber out of the aluminum to access the screws that attach it to the car.
    Jim
    Jim
    Jim
    I would like to reuse the rubber insert as it is an early S piece. Is it glued in? Would a heat gun help in getting it off? Any other techniques/suggestions?
    Larry
    Thanks E-
    Will give the hot squeeze method a try.
  1. FS: NOS rocker deco rubber 1968 - 1973 and deco trim hardware
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 02-02-2014, 10:34 AM
  2. FS: 73 rocker deco
    By Scotty B in forum For Sale: 911 Parts
    Last Post: 02-21-2013, 09:52 AM
  3. WTB 67S Rocker Deco(s)
    By 50/50 in forum For Sale: 911 Parts
    Last Post: 10-09-2008, 02:47 PM
  4. 67S Rocker Deco
    By 50/50 in forum Technical Info
    Last Post: 09-25-2007, 07:22 AM
  5. Removal of rocker deco strip?
    By ulrichd in forum Technical Info
    Last Post: 08-19-2007, 05:10 PM
