Thread: Help with ID of Cylinder
    I've been reading through a ton of forum posts between here and the Bird and can't seem to find an answer for what type of cylinder I have. I recently disassembled my engine to fix an oil leak and now I'm sorting through what's usable and what's not. I was able to ID the pistons as stock Mahle 2.2T pistons and hopefully they will spec out and be reusable. However, I can't figure out what type of cylinder I have. I don't think it's a stock Mahle cylinder because there are no markings that say Mahle and the only thing I've found are what appear to be almost ink stamps at the base of the cylinder. I've inlcuded pictures to help but here's what I see. I see the triangle with the height group of 5 so I've got that. There's also a circle with "X11 82" in it. Further, I see the number "503" printed over "WR 06". There's are no cast in Mahle stamps or the normal indented stamps I've seen in pictures of other Mahle cylinders which is what leads me to believe they aren't Mahle or original. Can anybody give me a hand? Thanks in advance.
    Stretch
    They appear to be stock cast iron T cylinders, don't over think it.
    Sounds good. I wasn't sure since all the others I'd seen had Mahle cast into them. Hopefully these are in good shape and can be reused. Thanks again,
    Stretch
  1. WTB: Cylinder heads, 2,2-2,4S
    By Mikael Berg in forum For Sale: 911 Parts
    Last Post: 07-31-2013, 04:50 PM
  2. WTB: 2.8 RSR cylinder
    By geneulm in forum For Sale: 911 Parts
    Last Post: 07-16-2013, 05:12 AM
  3. FS: Master cylinder #901-355-011-01
    By Dmill in forum For Sale: 911 Parts
    Last Post: 01-28-2013, 10:56 AM
  4. New ATE 930 Master Cylinder
    By Cornpanzer in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-26-2011, 04:17 PM
  5. 66: 2.0 std vs 2.0S cylinder
    By preS in forum Technical Info
    Last Post: 03-08-2009, 04:35 AM
