Thread: Source for rear parcel shelf harness bar mounting point
    Senior Member hgarazo's Avatar
    Jan 2004
    Frederick, MD
    I remember a couple years ago there was a thread discussing various harness attachment points on the rear parcel shelf. One of the suppliers had a "flat bar" with eyelets that bolted in between to 2 factory mounting points on top of the parcel shelf. I have seen some old factory photos with such a set up.
    Can anyone help me with the source?
    Henry
    Henry Garazo
    '68 Polo Red 911L Barn Find
    '70T 2.7 Coupe
    '58 1600S T2-A Speedster
    '87 Triple Black Carrera Coupe
    "Form Follows Function"
    Early 911S Registry #962
    Potomac Region PCA
    john gausden advtracing@gmail.com
    he is in NZ
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    Dec 2004
    SE Michigan
    Please post what you find here.
    Bill G.
    EarlyS #718 | RGruppe #437
    Jan 2004
    Frederick, MD
    Thanks Clyde. I will try him.
    Cheers,
    Henry
    Quote Originally Posted by BOYER73S View Post
    he is in NZ
    Henry Garazo
    '70T 2.7 Coupe
    Potomac Region PCA
    I have debated how to attach harness to the parcel shelf area and I settled on a different arrangement, using reproductions of the harness mounts that were used in the 914-6GT, installed in the area where the vertical and horizontal planes of the rear bulkhead meet, which is a lapped area between panels that are spot-welded together, with suitable backing plates inside the engine compartment. It's not neccessarily what you had in mind, but you might consider it.
    JR
    Jan 2004
    Frederick, MD
    No luck with John at adtvracing.
    I did find a pic of something similar. I remember seeing more of a wider, flat bar with harness eyelets. It should distribute the load better than just eyelets in the parcel shelf and big fender washers. Maybe it was TRE? I'll try them next. I guess it wouldn't be too hard to fabricate.
    Henry Garazo
    '70T 2.7 Coupe
    Potomac Region PCA
  1. WTB: rear parcel shelf
    By Nicklasliljegren in forum For Sale: 911 Parts
    Last Post: 08-03-2013, 07:39 AM
  2. SWB parcel shelf eye bolt mounts for harness
    By hoffman912 in forum Technical Info
    Last Post: 10-22-2012, 10:18 AM
  3. Replies: 11
    Last Post: 03-14-2012, 08:40 AM
  4. rear shelf interior pannel & shelf mounted harness
    Last Post: 07-26-2010, 06:09 AM
  5. 4 point harness mounting
    By jan in forum Technical Info
    Last Post: 01-20-2009, 08:50 AM
