Page 11 of 17 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 163
Thread: A gal named Elsie and her little Tornado...
  1. #101
    The Tornado LIVES!!!!!
    Pretty good amount of smoke until we got to operating temp.
    Name:  porsh start.jpg
    But after a drive around the block and some time running, all was well!
    Jake
    Early 911S Registry Member #2799
    1973 911S - "Tangerine Tornado" - Two Time SCCA Solo II National Champion (1976 and 1981)
    1967 Corvette Roadster (Black/Black/Black) 4-speed
  2. #102
    Senior Member platas's Avatar
    Jun 2005
    Spain/Houston
    Jake, a great story. I wouldnt touch anything, just keep it up to par. Congrats !
    San
    53 Pre A, 65 356
    70 914/6 GT
    65 912, 67 911
    71 911 Targa,72 E Tara, 73 911 Targa
    70 911 S,71 911 S,70 911 T,
    71 911 T, 72 911 E ,73 911 T
    74 911 Coupe
    74 911 Targa
    1972 RennSport Bus
    Early Reg # 771
  3. #103
    Glad to see "tornado" is running,,,,now you're happy,,,,, and so is "tornado'
  4. #104
    Time Bandit Jens's Avatar
    Aug 2003
    vahmont
    ..and it sounds good, too. Congratulations, another milestone.
    RGruppe #183
  5. #105
    Senior Member mrgreenjeans's Avatar
    Nord Stern Region of PCA....west coast side of Region
    I am so with you on the progress ......
    Sympatico ! ! !
    Best Regards,
    mrgreenjeans
    member # 1503
    -'68 -912 Red
    -'74 -914-2.0 litre - Sunflower
    -'82/83 -944 -M404 - Guards Red
    -'84 -944 -M456 - Guards Red -Weissach Prep. -H52
    -'84 -944 -M456 - Zermatt Silver
    -'84 -944 -M404 - Sunroof Delete - Ruby Red
    -'85.2 - 944 -M456 -Zermatt / Sport Purposes
    -'86 -944 -R74 Spt.Touring Pkg - White/Burgandy
    -'88 -944 - Jubilee Ltd. Ed. -Satin Black Met/Grey Plaid
    -'88 -911 - Tourist Delivery -Venetian Blue
    -'89 -944 Turbo M030 - Satin Black Met.
  6. #106
    Ordered new plug wires, cap, rotor and a Pertronix Ignitor for the Tornado last weekend. The cap and rotor were pretty bad, and I hate screwing with points... so the Pertronix seems like the obvious solution. Will give it a try and see what happens.
    Going to order a set of 195/65-15 Bridgestone Pole Position tires pretty soon. Then, I will just have to wait for frozen tundra to melt.
    Jake
  7. #107
    Installed the new cap, rotor, and wires this weekend.... also changed out the brake fluid and diff fluid. The diff fluid looked decent and there was very minimal metal on the magnetic drain plug. But, I was having difficulty shifting on the way to the shop. It didn't help changing the fluid and was the same going home so I guess this weekend's project will be looking at the linkage/coupling to see if that's worn. Anyone have any other suggestions?
    On the up side, it's running GREAT! And there isn't one bit of rust under the car... not even a little bit. I have one cylinder that seems to be weeping a little oil... not sure what that could be about, should it concern me?
    Jake
  8. #108
    What do mean when you say "difficulty in shifting" ? The linkage is vague, or the synchros don't work well? One could mean bushings and adjustment, the other could mean the wrong gear oil. Where is the cylinder leaking oil from? near the head, near the case? No it shouldn't be cause for concern anyway.
  9. #109
    The shifting issue is this: When I push the clutch in and pull the lever to change gear, the lever is resisting... kind-of "pops" out of gear... then it is a little hard to get into the next gear. Seems to be in all gears (except 4th which tends to go smoothly most of the time). Tends to be a little difficult to get into first gear in certain situations (after reversing, for example). I used 80-90w GL-5 for gear lube. Did I use the wrong oil? Are my syncros weak?
    The cylinder seems to be leaking from the base (close to the case). Oil is not dripping, but the case had oil on it under the cylinder... TIA for the help, Ed.
    Jake
  10. #110
    Sounds to me like perhaps the clutch is not totally dis-engaging. The reason it is not as bad in 4th is because you are closer to a 1:1 ratio. Try adjusting the clutch and verify that your cable is not stretching or failing.
    1974 911"S" - Silver
    10 sec 67 VW
    Early "S" Registry #439
  1. Replies: 6
    Last Post: 06-05-2005, 03:44 PM
