Results 1 to 9 of 9
Thread: photo of stock + battery terminal?
    Does anyone have a photo they can post of a stock battery terminal (positive)?
    Thanks!
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    That part is available from Sierra Madre
    M.A.Spirito
    Feb 2012
    Edmonton
    I see the Pelican thread shows the SWB terminal, the LWB terminal is slightly different.
    I just replaced both batteries, + terminals and ground straps in July. Got all the parts from the local Porsche dealer.
    I'll take a pic of the LWB terminal and post it later today.
    The LWB terminal has provision for two battery cables to be clamped in, the SWB only one.
    Feb 2012
    Edmonton
    Here's a couple of pics of the LWB + Terminal
Size:  115.1 KBName:  SAM_2584.jpg
    Thanks, all. Any idea how wide that LWB terminal is?
    I'm looking to find a vinyl type cover for the + terminal (I am using an Optima battery).
    I've also heard that these clamp-on terminals are not as good electrically as the ones that solder on. True?
    Quote Originally Posted by 37yrold911 View Post
    You are correct that the original terminals (clamp type) will not have "as good" a connection as a solder-on style. Over time, the clamp-on style will corrode faster than a solder style because it allows air to react with the copper at the connection. But, the clamp-on is a stock connector for LWB as JRBennett noted.
    Jake
    Early 911S Registry Member #2799
    1973 911S - "Tangerine Tornado" - Two Time SCCA Solo II National Champion (1976 and 1981)
    1967 Corvette Roadster (Black/Black/Black) 4-speed
    So every couple years you remove the cables wire brush them clean and reinstall. Have you ever tried to solder that large of a cable to a ring connector? You won't do it with the normal small soldering iron. Pep boys have the vinyl rubber protectors to put over the positive cable clamp.
  1. Battery Terminal Covers
    By RC70SCoupe in forum Technical Info
    Last Post: 03-30-2014, 04:28 AM
  2. Photo of a 911 being used ... in the day
    By john rice in forum General Info
    Last Post: 02-19-2009, 06:09 PM
  3. Sealed Battery Recomendations for Battery Box
    Last Post: 11-13-2007, 05:31 PM
  4. Photo for DAN !
    By Francois Duval in forum General Info
    Last Post: 12-17-2004, 08:52 AM
  5. Twin battery to single battery conversion
    By bulldog in forum Technical Info
    Last Post: 03-30-2002, 09:44 PM
