Thread: Diameter of + Battery Cable?
    Does anybody know the diameter of the positive battery cable on a 1973.5 car?
    I am looking for a precise fit for a solder on terminal, so I need to know the AWG on it.
    Also, curious if I really do have a stock cable, so closeup photos are welcome...
    Thanks!
    According to a post I answered 5 years ago ,310" bare end, no insulation.
    Do we know if wire gauge of second battery is same?
    Yes it is.
    Jun 2011
    Mound, Louisiana
    I am finding tables that will cross reference inches to AWG size. As far as I can tell, that is in between 1 and 0 gauge.
    I was wondering what size it was. When I bought some took a sample with me and it matched up closest to 1 gauge. I'm using welding lead.
    Paul Harrop 12.5% German.
    Early S #2059
    Member bboss's Avatar
    Jun 2012
    Dallas, TX
    I believe all the wire on early Porsches is metric gauge (not AWG / Brown & Sharpe). Based on Ed's measurement, I bet it's actually 8mm.
    Here is a chart I have bookmarked from wikipedia that may be helpful or at least interesting: http://upload.wikimedia.org/wikipedi...auge_Chart.pdf
    Also, AWG for multistrand wire is not really diameter based - it is driven by ampacity or the sum of the gauge of the individual strands. Therefore welding cable (which has a lot more strands for a given gauge) will have a different overall diameter than automotive wire.
    If your goal is to match the ampacity of the original wire, I think you would be better off with 1/0 than 1 awg.
    Hope this helps.
    Brian
    Quote Originally Posted by dummkopf View Post
    Brian Boss
    71 914-6 2.2E conversion
    71 911T mostly S spec____________
    Early S Member # 2758___________
  1. WTB: 73 911 negative battery cable wing nuts
    By mac73s in forum For Sale: 911 Parts
    Last Post: 04-04-2014, 10:48 AM
  2. Replies: 9
    Last Post: 02-10-2014, 08:31 PM
  3. FS: Early 911 dual battery positive connection cable
    By MountainRoads in forum For Sale: 911 Parts
    Last Post: 03-11-2013, 06:29 AM
  4. Where to get a new cable housing for the hood release cable?
    By Sandwich Boy in forum Technical Info
    Last Post: 07-15-2009, 05:31 PM
  5. PO just cut second battery cable.
    By ulrichd in forum General Info
    Last Post: 10-08-2007, 04:05 PM
