Page 2 of 22 FirstFirst 123412 ... LastLast
Results 11 to 20 of 217
Thread: '73 Porsche 911 S Restomod Build
  1. #11
    Member chriskimmelshue's Avatar
    Jun 2013
    Nashville, TN
    Some "deconstruction" photos:
  2. #12
    Jun 2013
    Nashville, TN
    Best way to introduce yourself? . . . .
    . . . is to share your project
    And any more details? . . . . model, engine, trans, miles, blah/blah/blah
    . . . and welcome aboard
    The S had about 57,000 miles on it, but the PO cannot confirm it. I'm expecting a stack of paperwork documenting the Brumos "build". The engine is a bit of a rare bird. More details on that later. It still uses a 915, but has a LSD in it.
    As it came from the factory:
  3. #13
    Senior Member Swiftmotoring's Avatar
    Nov 2010
    Bloomingdale GA
    Quick question.....why move forward with the restoration while waiting on paperwork documenting a Brumos build?
    Marvin Waters
    25 Yr PCA Member
    10 Yr Early S Registry Member
  4. #14
    Junior Member
    Feb 2012
    Im subscribed
  5. #15
    Quote Originally Posted by Swiftmotoring View Post
    Yeah, I'm going to second that comment. If there is value for a true special car from Brumos, why not retain that and make a hot rod out of something that doesn't have separate value? I guess to each their own, and the owner of any car certainly has the right to do whatever he wants with his possession. Still.
  6. #16
    Don't modify a Peter Gregg special 911. I have a Club Sport that I can sell you if that is what you are after
    Don
  7. #17
    Jun 2013
    Nashville, TN
    The main reason is to bring the car up to my standard. The modifications performed aren't that impressive, honestly.
  8. #18
    Jun 2013
    Nashville, TN
    Quote Originally Posted by Jay Laifman View Post
    I'm less than impressed with what Brumos did other than the wide body look. The induction system on the 3 liter block is all wrong. The welding was done by an apprentice or a 3 year old, I cannot decide. I'll keep the "spirit" of what they did, but I will have it brought up to snuff.
  9. #19
    So are you saying that's a 3.0 MFI engine? What is it that is wrong with the induction system,,,just curious. And by the way, you need to mount the yoke on the other side of the engine.
  10. #20
    Jun 2013
    Nashville, TN
    It is indeed a 3.0 MFI. It has an RSR case, pistons, and cylinders. The crank is S/C. The heads are modified 3.0 RS heads for twin plugs. The throttle bodies and stacks are plastic 2.4. The pump is 2.4. The cam journals are S/C. The oil pump is from a 964 (dating it to a possible rebuild post Brumos?). Mixing and matching at its finest.
    I've seen the yoke on either side and have used it on either side. The opposite side has a threadsert in it and I didn't trust it. Moot point now as it is with SuperTec.
  1. Another 72 ST build
    By BOYER73S in forum General Info
    Last Post: 05-20-2023, 07:39 AM
  2. Replies: 13
    Last Post: 04-05-2014, 05:14 AM
  3. Porsche 911 "80's" build
    By obrut in forum Other Porsche Passions
    Last Post: 09-25-2013, 06:49 PM
  4. Not a Porsche but what a build...
    By 767driver in forum Other Car Cultures
    Last Post: 01-11-2012, 05:59 PM
  5. How Early Did Porsche Build 9X15s??
    By byron in forum General Info
    Last Post: 10-05-2011, 01:13 PM
