Thread: Uprated SWB Drive Shafts
    I have been worrying about Hub/CV joints on SWB cars for some time now.
    Last year we made new hub flanges for the trailing arms and we have been refurbishing CVs for a while now but good core units are becoming difficult to find.
    I have decided to make new flanges for both the wheel hub and the transmission and use the 100mm diameter CV.
    GKN Motorsport make a lightened version of this CV with +/- 14mm of plunge. The 25 spline bore is compatible with the original SWB Drive Axles.
    We will make them from a 300M VAR Steel and fully heat treat to a condition that will optimise fatigue performance.
    Should be done by early 2014.
    Port Macquarie, Australia
    Hi Chris
    Please keep me in the loop on these - I suspect I'll need a set
    John Forcier
    EarlyS #1987
    Restoration Saga
    Dec 2008
    Woodland Hills, CA
    What does it typically cost to refurbish original CVs if the cores are supplied?
    Aug 2013
    SoCal
    I would be interested too! Is there a list to get on?
    Quote Originally Posted by chris_seven View Post
    Will you be making transmission flanges for all SWB differentials? There were three versions.
    Jon B.
    Vista, CA
    John,
    I don't think we will make one for the simplified diff as they were not great at the best of times.
    We will make one for the original diff but try to do away with the need for the aluminium cap and also one for the LSD that used a Lobro.
  1. Rocker Shafts
    Last Post: 05-17-2013, 12:49 PM
  2. FS 906 web cam grind Cam shafts
    By budge96 in forum For Sale: 911 Parts
    Last Post: 10-04-2012, 02:59 PM
  3. Fs: Nos lwb rear drive shafts
    By andrea70 in forum For Sale: 911 Parts
    Last Post: 10-01-2012, 09:49 PM
  4. 2 '0' intermediate shafts f/s
    By silveranger in forum For Sale: 911 Parts
    Last Post: 02-07-2012, 04:20 PM
  5. info on CVs and half-shafts
    By 37yrold911 in forum General Info
    Last Post: 03-11-2011, 12:40 PM
