Thread: 2.7 L engine number location ???
    Junior Member
    Oct 2013
    I am considering purchasing a 911t with a replaced engine. It is to be a 2.7 case out of a 1977 model, ,however no serial# on it. I have not seen the vehicle yet.
    Shouldn't there be a stamped number on the case? Is it possible that a dealer may have had a replacement without a number at any given time?
    Any info is much appreciated.
    Junior Member
    Dec 2012
    New Orleans, La
    should be by side of the fan
    Junior Member
    Oct 2013
    But if it's not, is it possible to have a block/case without a number on it?
    Oct 2008
    Burford, ON, Canada
    Absolutely. A replacement case has NO numbers except the case pairing # stamped into it.
  1. 915 gearbox type number location
    By manu72S in forum Technical Info
    Last Post: 05-29-2009, 01:25 PM
  2. Engine Number
    By mwilson3003 in forum Technical Info
    Last Post: 08-03-2007, 01:29 PM
  3. vin number location
    By Francois Duval in forum General Info
    Last Post: 12-29-2006, 08:47 AM
  4. Engine Number Location(S)
    By MVANBENS in forum Technical Info
    Last Post: 08-07-2006, 08:02 PM
  5. engine bay sticker location
    By pu911rsr in forum Technical Info
    Last Post: 09-10-2005, 10:17 AM
