Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 105
Thread: The starting of the stripping process
  1. #91
    May 2008
    Sydney
    A special day today.......i finally removed the vin tag, it now sits in the drawer with the dials.
    step 1
    step 2
    step 3
    Now i only have one bolt to remove from the steering column and the last oil line from the oil filter and the shell will be ready to be cleaned and paint removed. I am waiting on a air compressor and a couple of other things...progress is getting there slowly but surely, as I read somewhere these things are marathons not sprints.
    I am breaking it down into little jobs as well, so ordering a few parts to do some small jobs. Job 1 is to redo the brass bushes in the pedal box. With this in mind do people powder coat the pedals and pedal box or just paint with a semi gloss black paint ?
    Below are some before shots.......after shots to follow in due course
    Clayton Shipard
    Sydney, NSW Australia
    1972 911 2.4S
    2000 Boxster S
  2. #92
    May 2008
    Sydney
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  3. #93
    Port Macquarie, Australia
    Clayton, learn how to use 2k paint... I powdercoated the big things like suspension components etc..., but you'll move forward a lot faster if you can make yourself up a paint booth (old cardboard wardrobe for example) and learn to mix two-component epoxy and polyurethane paints. The finish is superior to anything out of a can, and will literally last a lifetime if looked after. Satin black is merely gloss black with some matting agent mixed in so you can adjust it as you need...
    John Forcier
    EarlyS #1987
    Restoration Saga
  4. #94
    May 2008
    Sydney
    Ok thanks John, thats another reason to add to the list, hence i am getting/waiting on a compressor......so will start learning the 2k painting as well.
    I am now starting to understand its the journey not necessarily the destination.......saying
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  5. #95
    May 2008
    Sydney
    soaking the second ball joint pin must have done the trick as 4 bangs this morning and it popped out.........not to seperate the ball joints and working on the tie rod joints as well.........guessing this is what older cars are like........lots of sweat but good satisfaction when there is progress
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  6. #96
    Jul 2004
    Sydney, Australia
    Clayton - great work
    I am sure you're aware - but LHD and RHD pedal clusters are different ?
    cheers Paul
    Paul
    1969 ex-South African RHD Tangerine 911T . 1970 ex-Southern Californian LHD Conda 911T 1955 Series 1 86" Land Rover (original Australian CKD … very slowly re-building) 1987 W124 230e
    (long term paid up member)
  7. #97
    May 2008
    Sydney
    Hey Paul,
    Yeah I have a left hooker so everythings' different Hahahaha
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  8. #98
    Jul 2004
    Sydney, Australia
    …. good …. i was just checking (!!!)
    Great work indeed - i'm really enjoying the progress !!
    Paul
  9. #99
    May 2008
    Sydney
    I was away the whole week for work, so progress has been slow.
    That said i finally managed to remove the oil filter assembly
    And also managed to remove the last one time use bolt on the steering column so now the steering column is out
    so only have the three minor switches to remove then the shell is totally stripped...
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  10. #100
    May 2008
    Sydney
    so i have a question as there is one wire i am trying to confirm if its for the sunroof......can anyone confirm it for me from the photos ?
    It is also stuck from the bottom going down the a pillar so not sure what is it....will have to investigate it a bit further
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  1. Magic rechrome process
    By adam912 in forum Technical Info
    Last Post: 10-02-2012, 02:24 PM
  2. Stripping, dipping and Ecoating
    By nick-moss in forum Technical Info
    Last Post: 08-05-2012, 07:38 PM
  3. Stripping Undercoating Need Ideas Please
    By FHernand in forum General Info
    Last Post: 11-26-2006, 10:01 AM
  4. New PCA COA process
    By pu911rsr in forum General Info
    Last Post: 10-20-2006, 04:53 AM
  5. Signal Color Process
    By rsr1975 in forum General Info
    Last Post: 01-31-2006, 07:19 AM
