Thread: template available for radio antenna placement?
    Is there some sort of template or reference out there to assist with exact placement of the driver's side antenna?
    Thanks!
    1974 MFI Carrera
    1992 Carrera RS
    S Reg #1245
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    if you have a manual antenna it should sit on the left side...open the driverdoor and have a look on the inside of the fender sometimes there is already a hole punched or a mark where it schould be drilled..on the inner metal layer.
    the elictric antenna sits on the right fender but since it has a more forward position there is no mark...there is only one metal layer .
    I've got one.
  1. Radio Antenna?
    By greens in forum Technical Info
    Last Post: 12-20-2013, 06:27 AM
  2. Anyone have a radio template?
    By jlandreth in forum Technical Info
    Last Post: 08-26-2009, 08:28 AM
  3. Antenna Template for RHD car
    By Andy B in forum General Info
    Last Post: 08-07-2009, 07:00 PM
  4. 67S Radio Antenna Question
    By pacarguy in forum Technical Info
    Last Post: 05-14-2008, 03:49 PM
  5. Automatic Antenna Placement 1972 911S
    By lotus15racer in forum Technical Info
    Last Post: 03-04-2006, 05:32 AM
