Mark Erbesfield
1973 911S #9113301282
1957 356A #58648
1982 Toyota Land Cruiser FJ40
1977 Toyota Land Cruiser FJ40
1979 MB 450SL "Dad's old car"
2019 Cayenne "Wife's car"
What is your goal? If anything, its more labor than starting with a 911 to begin with, so that chassis better be close to costing you nothing. Otherwise wiring harness, engine mounts, suspension, brakes, chassis mods will outweigh the cost difference between shells.
Go cheap? say take a complete 912E, and install a carbed 911 in it? You will have figure out wiring, tach and oil guages, smaller main shaft on the trans- clutch differences< yes a 7:31, but weaker than a 915. Oil tank, cooler? So you will end up with a ill handling (small rear torsions), so so braking (small brakes) car unless you change those out too.
When building shells into race cars, they were good donors as most had no sunroofs, and you were replacing everything anyway
912-6's don't enjoy a decent resale $ per $ spent vs a "real" 911.
Ok !! Now I understand !!
Yes Sr. Weidman is in the right way !!!
You think the perfect sizes for search is dunlop 550 rear with 7" and dunlop 500 front with 6" !!! Ok ??
When have the car finished I have four 6 Oem fuchs ( in this would mount the perfect size for going to breakfast with my friends ) and have one other four mounted with r888 in 195/50/15 for when go to the track or make one rally........
I would check prices again, at least over here in EU where you already pay close to 50K for a T.(not in restored state) since prices of good 912's are not over 30K yet there is some 10/15K which you safely can put in the rebuilt. So as result you end up with a much more healthier and fun car to drive than that old T that prob needs some work to.
building an outlaw or whatever you want to call it is better done from a 912 since 911's are more worth as they stay original (for some at least) since an outlaw can never be "not correct" because it's personal taste, it seems better to go for the "less" desirable car to start with.
my guess is that more and more 912 will be used for this, especially the SWB cars since the 911SWB will be too expensive to rebuilt as an outlaw.
just my 0.2s
1988 3.2 Carrera
@joost_hermes
S Registry # 2292
Exactly !! I think the same Sr. Hermes
The price of my car because need a lot of work and need one reconstruction is low price............ Because one Oem SWB is súper súper expensive.
I think now with this times the only way because the 912 step by step the the prices up very is because more 912 are selleds for the workshop and more workers on bodycars make conversions to 911's racing SWB !!!
I look this Sr. Dezzmo, but not understand because can not conntact to this company !!!
I make fhone calls and not respound...........
I send in the webpage the sistem for send one email, because not have direct addres and not respound.......
I would buy one pair of 2R model ........... But can not make without any contact !!!
Thanks for the clarification Jim
Tim G
Early S Reg #1017
RGruppe #663
73 911T 3.2
00 Ducati 996 Track Rat
01 Ducati S4 Monster
