Thread: Rear Caliper Identification: Ate 51R
    Hi Guys
    Could I get some help identifying the rear calipers that came with my car (69E). They are stamped with Ate 51R and the piston diameter is 48mm. I need to rebuild them, and the seals in the Pelican catalogue for MY 69 are 38mm in diameter. Therefore, I'm thinking these calipers are from a different car?
    I'm trying to avoid ordering the wrong parts.
    Darren
    Name:  Rear Calipers.jpg
    Oct 2008
    Burford, ON, Canada
    48mm pistons say that this is a front caliper; brake line connection shows this also. These are too big for the rear since it will cause the rear to be over-braked. You need the proper rear calipers.
    I found a thread elsewhere on this topic and added to it. The ear spacing is 3", so definitely not Porsche Fronts. As indicated in that thread, these must be from a different car.
    http://forums.pelicanparts.com/porsc...mm-piston.html
    Aug 2009
    SF Bay Area
    Quote Originally Posted by Djthom View Post
    They are definitely front M calipers. They are Porsche calipers but will not work as rear calipers on your car.
    Jim
    Aug 2009
    SF Bay Area
    I just read that thread. Holy Cow! What a bunch of mis information and BS!
    Ciao
    Jim
    Thanks guys. For someone new to Porsche, I certainly need to be carefull what I find and read. I always tend to look or ask here on this board first. I also emailed back and forth with Eric at PMB who gave excellent advice and also confirmed also that they are M calipers. Thanks for all the support. I will need to exchange these for a pair of proper rears to maintain the proper fore/aft balance.
  1. Rear SWB vented caliper kit. (all new parts)
    By Alan.uk in forum Technical Info
    Last Post: 10-28-2019, 08:43 AM
  2. Caliper identification
    By Bantam in forum Technical Info
    Last Post: 08-29-2013, 07:02 AM
  3. rear brake caliper
    By Francois Duval in forum Technical Info
    Last Post: 11-30-2009, 05:26 PM
  4. Koni Rear Shock Identification
    By CamBiscuit in forum Technical Info
    Last Post: 06-18-2008, 05:14 PM
  5. L-Caliper Identification Thread
    By Neunelfer in forum Technical Info
    Last Post: 05-03-2008, 04:35 PM
