Thread: How do I separate a 901 trans from a seized 2.2 from a 71 911T?
    Jul 2012
    Cedar Park, TX
    Any thoughts on the best way to separate an original 901 from it's original motor that is seized from a 71 911T?
    As I understand it, normally the starter would be removed and the motor would be rotated to insert 3 socket head screws with spacers to release the pressure plate. Given the motor is seized rotating the motor is not an option. It is specific to 70's and 71's I am told.
    Thank you in advance.
    Quickest way is to rotate TO bearing 90 degrees so throwout arm is no longer engaged, then slide tranny back away from engine and you're done!
    Dave
    Oct 2010
    Southern Ca.
    Dave is correct . Pull on the end of the release fork to make it easier to turn the TO bearing .
    There are flats that the arms of the release fork lay into of the TO bearing. When you pull against the leaf spring the arms come off the flats. Rotate 90*, wala.
    Jul 2012
    Cedar Park, TX
    Thank you all, I will try to get it separated possibly tomorrow now that it's not 35*F and raining. I guess it could be worse, but for a warm weather kid it's cold.
    Banned
    Nov 2004
    Scottsdale, AZ
    It hasn't been much warmer in Tempe the last few days...
    Make sure the engine and trans are still bolted tight, otherwise you won't be able to rotate the brg.
  1. Bruce Meyers Whittington 935 K3 Seized by DEA
    By Nine17 in forum Drives, Tours, Gatherings, Racing and Adventures
    Last Post: 01-13-2014, 07:55 AM
  2. Replies: 0
    Last Post: 09-19-2013, 07:04 AM
  3. Seized brakes - seeking a little advice
    By shed7 in forum Technical Info
    Last Post: 11-10-2011, 08:24 AM
  4. Early 911 Sporto seized?
    By JT912 in forum Technical Info
    Last Post: 08-19-2010, 08:29 PM
  5. GT-R's Seized by Feds in LA
    By CurtEgerer in forum Off Topic
    Last Post: 10-05-2009, 10:51 AM
