Results 1 to 7 of 7
Thread: Help with 1967 Paint Code 97-3002
    Need some help with this paint code 3002. Checked all the usual references with no luck.
    Thank you,
    Thomas
    Early S Registry #1227
    912 Registry
    PCA - Sequoia Region
    Oct 2008
    Burford, ON, Canada
    That is a new one for me. Possibly the Kardex may say something. Is there any evidence of the original color? Another one for me to work on.
    Nov 2003
    Santa Monica CA
    Custom color ordered? Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    I was thinking it was a custom non-standard color. Hopefully we will see the original paint when we pull the dash in the next few weeks.
    912 Registry
    Oct 2008
    Burford, ON, Canada
    Yes, you may be lucky to find some original color there. Maybe even luckier if they wrote the paint name on the right side of the dash. Also look under lid brackets, latches, and even the paint badge. Some have found original color in the front lid under the compartment light.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    hmmmm ..i know that RAL it is not a porsche code maybe it is RAL3002 that would be kaminrot... used very often on european fire brigade cars.
    off topic:the leather interior colours on G-models are very often RAL colours..even if porsche calls it differently.
    Carmine Red RAL3002, good call. We've seen RAL on another Porche , 2002 Tangerine.
    The red you see around the tag match's the paint under the dash and the vin is still hand written across it.
    912 Registry
  1. Paint code 438 ???
    By rick2 in forum General Info
    Last Post: 12-03-2021, 06:42 PM
  2. Wanted: paint code plate w/ Conda green code
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 11-05-2009, 07:33 PM
  3. Name that paint code..
    By budge96 in forum General Info
    Last Post: 08-08-2009, 10:55 AM
  4. Paint Code ID
    By SKWIKY67 in forum Technical Info
    Last Post: 09-06-2007, 09:20 PM
  5. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
