Results 1 to 10 of 14
Thread: Identifying this Gas Tank Size
    May 2008
    Sydney
    Hi All,
    I am in the process of stripping my 911 and I am trying to verify the capacity of my fuel tank, its meant to be 100L
    i found a similiar one on http://retro-sport.com/products/911-...fuel-tank.html
    but mine is tu1 0040170 as per the photo below, does anyone have any info or know if this tank is 100L tank
    Name:  Porsche updated photos 042.jpg
    cheers
    clayton
    Clayton Shipard
    Sydney, NSW Australia
    1972 911 2.4S
    2000 Boxster S
    I guess you could measure out 100 l. of water and see if it all fits
    May 2008
    Sydney
    Yeah thats my second choice, thought i might see if anyone knew its size from the numbers on the tank. I will try the fill and empty method in the next couple of days.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    The original RSR tanks on our site are definitely 110 liters - not 100. If you post a few photos of your tank I'll bet we can tell you the size.
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    May 2008
    Sydney
    Hi Jordan,
    I will take some more photos tomorrow, your help is greatly appreciated.
    cheers
    clayton
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    for what it is worth here is the stamping on my 1973 85 litre tank as fitted at factory when new
    seems to read 029 - 0172 with date code 5 1973 (the car was completed in late June 73)
    also the letters do not look nearly as crisp as yours
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    May 2008
    Sydney
    Thanks Hugh I appreciate your help.
    I am going to post some more photos as requested by Jordan and see if that helps. Otherwise it might be the good old fill it up and measure how much comes out method.
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    May 2008
    Sydney
    Hi Jordan,
    here are some more photos of the tank, hopefully this helps you to identify my tank, thanks in advance.
    Name:  Porsche updated photos 009.jpg
    Name:  Porsche updated photos 010.jpg
    Name:  Porsche updated photos 011.jpg
    Name:  Porsche updated photos 012.jpg
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
    Dec 2004
    Melbourne Australia
    Hi Clayton
    it "looks" about the same size as my 85litre tank....... but is a bit different / earlier and maybe "fuller" on the bottom or perhaps a bit deeper? if so it could hol more but it is hard to compare when most of mine is hidden
    what is the date stamp on it? i could not read it on my screen
    the larger capacity tanks i have seen, or seen pictures of are shaped differently,,,,,, but i may be wrong and this could be a deep version of mine and hold another 15 litres (not that much depth needed to do that spread over the size of the tank)
    Hugh Hodges
    73 911E
    Melbourne Australia
    May 2008
    Sydney
    Hi Hugh,
    The date is 1972, same as my car, i am pretty sure it came with my car from the factory.
    cheers
    clayton
    Clayton Shipard
    1972 911 2.4S
    2000 Boxster S
  1. Need new fuel tank: whats the biggest with full-size spare?
    By Veronica87911 in forum Technical Info
    Last Post: 03-17-2014, 01:54 PM
  2. Replies: 3
    Last Post: 02-08-2014, 06:02 AM
  3. Need help identifying a connector
    By Max (SD) in forum Technical Info
    Last Post: 10-27-2010, 08:49 PM
  4. Help on identifying a car
    By goldsc78258 in forum Technical Info
    Last Post: 01-23-2008, 04:07 PM
  5. Identifying 901 Trans
    By mcgarryla in forum General Info
    Last Post: 05-24-2005, 12:10 PM
