Thread: Reproduction Paint Plates
    Hi all- One of the goober PO's drill holes for speaker wires through the paint plate. It's also pretty mangled, so I planned to replace it. The repro part 901.701.111.05 is 7mm shorter than the one removed from the car. The fonts and format of the Karosserie and Kunstharzlack boxes are different too. Where can I get a blank plate identicle to the original?
    As always, thanks a lot in advance.
    Cheers,
    Ron
    1961 356 Roadster Outlaw
    1969 911E ROW Coupe ‘Orangina’
    1968 911 SWT Burgundy Red project
    Feb 2010
    San Francisco, CA
    You might try International Mercantile
    http://www.early911sregistry.org/for...nt-plate-punch...
    E911SR & RGRUPPE
    '73 S Coupe #306
    Hi Kent- Thanks again for the reply. Yes, it looks like IM part # M548 is the plate I need.
    Another question, was it standard to leave the Karosserie box blank?
    Cheers,
    Ron
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    My 66 PORSCHE built 911 has the car serial # there! The lower block has the paint code. Not sure if your car is a PORSCHE built 911 or a KARMANN built 911 or in fact a 912 or year?….Cliff
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Cliff View Post
    have seen a blank serial box a on some cars but most of the time there is the vin stampt.
    if its a karmann body the plate has a karmann lettering on it.
    IM offers also a stamping service for the plate...but unfortunately they have only on type of fonts so it might be the incorrect one for most since at least 4fonts have been used in the early days.....karmann and porsche used also different ones in the same year.
  1. Replies: 6
    Last Post: 07-04-2013, 11:53 AM
  2. FS: 911 Scuff Plates Sill Plates / Carpet Hold Downs
    By 76911S in forum For Sale: 911 Parts
    Last Post: 11-05-2012, 08:34 AM
  3. Engine Fiberglass Cover-to paint or not to paint?
    By Varooom in forum Technical Info
    Last Post: 03-28-2010, 05:44 PM
  4. how do I remove paint from paint code plate?
    By 911scfanatic in forum Technical Info
    Last Post: 10-26-2005, 06:00 AM
