Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: 1972 911T front cross member / suspension welding
    Senior Member SpawnyWhippet's Avatar
    Mar 2013
    San Francisco Bay Area
    I've just bought a 1972 911T and after inspecting the front cross member more closely and pulling off some underseal, I discovered rust around the suspension bolt points on both sides of the pan. The passenger side is considerably worse than the drivers side, which is a bit soft.
    There doesn't seem to be any significant rust anywhere else on the car.
    How difficult is this to repair - does it need a whole new subframe, or are there good welders out there who can fix this one? What kind of $ could this run to?
    Does anyone recommend a good welder in the SF Bay Area, CA?
    Passenger side 1
    Name:  2013-12-02 22.27.35.jpg
    Passenger side 2
    Name:  2013-12-02 22.27.48.jpg
    Drivers side
    Name:  2013-12-02 22.27.58.jpg
    Thanks in advance
    Andy
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    2008 Cayenne S (sold)
    2004 Cayenne Turbo (sold)
    2009 997 cabriolet (sold)
    2002 996 Turbo (sold)
    1998 Boxster S (sold)
    1997 993 cab (sold)
    1989 911 3.2 Carrera (sold)
    You need a new pan. There is always more rust than there appears and the only way to fix it safely is cut away until you find solid metal, then weld in a replacement panel. Make sure you get the bolt point reinforcement pieces. They are small and often overlooked as they don't come with the larger panel.
    Probably $1500 done correctly.
    "Correctly" means you take everything to bare metal so you can see the extent of the rust, which as Max says, is more extensive than meets the eye. Then you either use a Celette bench or a factory or factory-style jig to ensure alignment of the new pan. This way the suspension mounts don't bind, there are enough issues with collinearity as it is.
    Aug 2009
    SF Bay Area
    Replacing the front suspension pan and the gas tank support is no different than changing oil.
    It is a "scheduled maintance" item.
    It is just done on a 20 to 40 year interval, depending on the environment it is exposed to.
    Jim
    PS: Call me for recommendations on experienced/Qualified/Competent/ethical Bay Area repair people.
    510-653-EASY
    Mar 2013
    Hi, can you advise who will do it for this price? I have called half a dozen bodyshops and Porsche specialists and the cheapest quote was 'starting around $2500, excluding parts and taxes'.
    The highest quote was $4k, from someone who does this particular job frequently on older 911's. One bodyshop said they could weld up the old front pan for about $1000, but I would feel happier about getting the pan replaced rather than repaired.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    May 2011
    Chelsea, Québec
    I would advise calling Jim as he suggests...
    Member #1616
    Oct 2005
    Minneapolis, MN
    $1500 is cheap.
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Mar 2013
    Quote Originally Posted by Flat Six, inc. View Post
    $1500 is cheap.
    Yes, I called Jim, he gave some very useful advice and pointed me in the direction of his preferred guy, Dave. I spoke to Dave who seemed very knowledgeable, but he was on the expensive side. If that's what it costs to get a good job, then I will pay it, but it was close to 3 times the price that people on here have told me it can done for.
    Member # 2899
    1972 911T
    2004 996 C4S
    2001 996 Carrera
    1997 993 cab (sold)
    Mine are also on the 'three times more expensive' side of things. Let me tell you about the budget jobs held in with sheet metal screws!
  1. Replies: 3
    Last Post: 06-04-2014, 09:01 AM
  2. FS: Later A-Arms, Cross Member Assembly; $75
    By ibmiked in forum For Sale: 911 Parts
    Last Post: 01-07-2012, 01:30 PM
  3. front cross member
    By Francois Duval in forum For Sale: 911 Parts
    Last Post: 11-28-2009, 04:39 AM
  4. FS: Transmission Cross Member
    By Mudi in forum For Sale: 911 Parts
    Last Post: 09-04-2007, 07:06 PM
  5. Aluminum cross member $125
    By p-thomas in forum For Sale: 911 Parts
    Last Post: 08-06-2007, 08:13 AM
Tags for this Thread
