Came across this post --- describing Factory identification of a higher-than-standard-spec motor . . .
http://www.911e.org/microsite.php?9113200707
This post was never answered. Has anyone ever heard of this?
On a tour of the Factory in 1979, one of the folks on the tour told us he had looked at the tags on the engines lined up around the Engine Test Stand (see photos below) and had asked that a particular engine (highest output) be installed in the car he would be picking up later in the week. I know he was a very good customer (over 30 cars purchased since the 50's) and would likely have had his request acted on.
But I have never seen a 'green tag' on an engine in any of the tours I took in the 70's or 80's.
Joe Hartman
Early 911S Registry #157
R Gruppe #174
356 Registry
I've not heard that either.....
However, as I think I've said here before, I know someone who roomed with a guy that worked 'on the line' back in the '70's. Assembly line workers did rotate jobs and, if you did your worked well would eventually rotate to be one of the '1 gallon road testers' and evaluators (as depicted in the film doc. 'One for the Road') This guy said when he tested the cars they all ran good... but some ran a little better then others.....
I love to think of the possibility that what he said to my friend was true..........
When I toured the factory in the early 70s, I was told that if an engine did not dyno enough hp, it would be torn apart & rebuilt. If an engine was on the other end of the curve, it would be put aside for special customers
Tom
Bümp!
Been a while, I know --- coupla years, almost --- but . . .
. . . has anyone else read about/heard of/come across this term?
Maybe some notations on a Kardex, bill-of-sale, Faktory docs, etc, etc, etc? . . .
Funny they have, what appears to be, an assembly line, production Tach on the Dyno gauge board
Does that mean it would not have paint drips and such? They built them to a pretty high standard already compared to other cars at the time. I question the idea that one 2.2 lyrics engine would be that much more powerful than another. 1+1 always equals 2- right?
Chuck
Early 911S registry #380
'70S
'75S
'96 C4S
'65 R69S
I went to the Porsche factory in 1998 and they said on the tour that every engine is is tested for horse power output and if the horse power was where it should be or more they left it alone, but if was less even by one increment they took the whole engine apart and started over, but no mention of green tagging at all.
