Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: 1972 911s with 911/83 engine value
  1. #11
    I didn't think the 7R came out until 1974?
  2. #12
    Feb 2010
    San Francisco, CA
    Quote Originally Posted by Flieger View Post
    7R cases came out durring the '73 MY. I'm sure someone else here could say EXACTLY when.
    E911SR & RGRUPPE
    '73 S Coupe #306
  3. #13
    Jan 2003
    NW Indiana
    Marc,
    Can you post photos of the serial number stamping as well as the type number 911/83 stamping? Please measure the size of the 911/83 numbers also. Thanks
    Brian
    '71T
    R Gruppe #299
  4. #14
    Hello all,
    Thank you for the additional info.
    I think it is wisest to first check the numbers we have with Porsche to see if they are indeed matching.
    I will let you know what comes out.
    In the mean time, thank you all for the help in this matter.
    Kind regards,
    Marc
  5. #15
    Hello,
    Hereby a picture of the 911/83 stamp on the case. I would think this is factory correct and supports the assumption that this is indeed a 911/83 case.
    It seems to lead to the conclusion that this case must have been resleeved to take 2.4 pistons. Would this be a common procedure?
    Also would such a resleeving mean that the case would first have been opened up a bit (to get a true surface for fitting the sleeves), or would it be most likely that there is just a 2.5 mm wall thickness ring pressed inside the unmachined original 97mm spigot opening. In other words, would be likely that it is possible to just remove these sleeves and have an intact 911/83 case?
    Thanks for any opinion on the matter.
    Kind regards,
    Marc
  6. #16
    Are you sure they are 2.4 pistons and cylinders?
  7. #17
    Feb 2010
    San Francisco, CA
    You will better confirm the type of cylinders by checking the number at the base if the cylinder. You should be able to see this by looking under the car, or in through the fan shroud.
    Good luck.
    E911SR & RGRUPPE
    '73 S Coupe #306
  8. #18
    Senior Member 210bhp's Avatar
    Feb 2004
    Scotland
    That looks like a factory stamp all right but there is no build number underneath it........ Davep, what do you think?
    Mike
    RS#1551(sold)
    67S
    Early S reg. #681
  9. #19
    They stopped putting the production # under the type# a few years earlier. How about a pix of the serial #. *663-----*
  10. #20
    Feb 2010
    San Francisco, CA
    Here's an example (not mine) of the cylinder type marking. A 2.4 will begin with 84Z* and a 2.7 will begin with 90Z* as in the photo.
    E911SR & RGRUPPE
    '73 S Coupe #306
  1. Looking for the 1972 911S chassis my engine came from
    By M491 in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 11-28-2010, 08:57 AM
  2. Replies: 0
    Last Post: 11-27-2010, 04:04 PM
  3. 1972 911S engine compartment color
    By lotus15racer in forum Technical Info
    Last Post: 02-12-2006, 04:43 PM
