Page 48 of 90 FirstFirst ... 38464748495058 ... LastLast
Results 471 to 480 of 895
Thread: Special early 1964 features on 1965 cars
  1. #471
    Solex Air Cleaner
    Look at this!!!
    Hattrick has a for sale item the needs a look at-
    http://www.early911sregistry.org/for...eaner-Assembly
    I am reposting his photos here to make sure they are searchable in the future.
    Note the left and right side air horns are two different heights.
    One is a shorter height without a cap indent. We will be looking at the inside of that in a moment.
    The other side, which is part of the Air Filter is taller in height and has a indent seam around it's cap. Also note it has a corner flattened to clear the engine lid.
    The inside is what I would like to focus on:
    The shorter of the two is without a center baffle (directing air to air horns) while the taller side has a center baffle with three air inlets centered on each of the carb barrel.
    As a comparison study I am including a different air cleaner (from a 1964 car) that has tall cans on both sides - baffles on both sides and a flattened corner. Sorry I did not keep this example to review the stamped date. (This will be in a separate post as the order or the photos is not as desired).
    My estimation is Wades air cleaner has 1/2 of the holy grail prototype to very early 1964 cars air cleaner that only shows up in prototype engines photographed for the very first Drivers Manual photos.
    Any thoughts?
    Bob
    Early S Reg #370
  2. #472
    Solex Air Cleaner comparison
    Here is the inside of a 1964 cars matching sides air cleaner - both sides are the same height and both sides have the interior air baffles.
    Bob
    Early S Reg #370
  3. #473
    Mar 2012
    Scotland
    I am confused. I thought the baffle-less shorter type was earlier type and the baffled taller type was the later type.
    Anyone wanting a shorter baffle-less right hand section can contact me as I have one spare. Looking for $1500 plus shipping from Scotland UK.
  4. #474
    Does anybody know when the astray inside was changed?Name:  DSC09298 (Medium).jpg
    Specializing in the early 911
  5. #475
    Seasoned Veteran
    Jan 2011
    Northern Ohio
    Quote Originally Posted by DEEMAN View Post
    I agree I thought baffle-less was earlier??
    Proof being that the baffled side is the side with the 6/65 stamping making it late style???
    300359
  6. #476
    Senior Member pss's Avatar
    May 2014
    Netherlands
    Quote Originally Posted by Mashmotor View Post
    Good question. The only info I have is that the one with the hole in the middle is 1964, and the other one is 1965, but I cannot imagine this as I have seen several of these already. I would guess it was changed sometime 1Q 1965.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  7. #477
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by pss View Post
    would say so too.
  8. #478
    Sep 2006
    La Quinta
    #301111 has the hole in the middle.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
  9. #479
    Nov 2002
    San Dimas, CA
    301382 also has a hole in the middle.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  10. #480
    Apr 2011
    N.Calif., south of SF
    #302580 has the hole in the middle of the ashtray
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
  1. FS: Very early 4 screw dash top 1964 - 1965
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 12-29-2019, 09:11 AM
  2. Replies: 29
    Last Post: 11-23-2019, 04:41 PM
  3. Replies: 142
    Last Post: 10-22-2016, 05:46 AM
  4. Early heat exchangers 1964/1965
    By Milou in forum Technical Info
    Last Post: 01-14-2014, 10:53 AM
  5. Early 1964 tach and 1965 speedo
    By ixxifan in forum General Info
    Last Post: 06-15-2010, 12:24 PM
