Page 53 of 90 FirstFirst ... 343515253545563 ... LastLast
Results 521 to 530 of 895
Thread: Special early 1964 features on 1965 cars
  1. #521
    Senior Member pss's Avatar
    May 2014
    Netherlands
    I got my 356 grey ones from SM, do not know about their black quality.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
    964 RS clone (one of many)
    964 Targa original Dutch police car (one of 45)
    964 Turbo 3.6 (one of 1450)
    993 S Vesuvio (one of 250)
  2. #522
    May 2014
    Netherlands
    Quote Originally Posted by Ivan Fuller View Post
    Bob the pictures you show are from two different cars
    The tabs on one have clips to take a screw or bolt and the other doesnt.
    Anyway I have the plain tabs on 1022
    How late in production were they?
    And if so I need a panel as well
    I also have only seen mounts like in Bob's left picture (post 496) and combined with the carpet hooks. The ones in his right picture I have never seen, nor the board Franz showed.
    I would guess Bob's right picture car is 1964 and like Franz' car does not have the carpet hooks either (Franz, Bob, pls confirm); this was a known change from 64 to 65 and I have seen no 65 car without the carpet hooks (338 does not have them but seems an anomaly?)
    Ivan, on other features:
    - does 1022 have a gold colored 911 logo on the dash or is it silver? This has changed between 835 and 1111, hope to pinpoint this more accurately.
    - 6 fold seats changed to 5 between 984 and 1020. Can you confirm 1022 has 5?
    Cheers, J
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  3. #523
    May 2014
    Netherlands
    Franz
    I think you are correct. A better repro is ripe for the taking.
    Jim
    well at current market prices, that might be lucrative ;-(
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  4. #524
    Quote Originally Posted by pss View Post
    Cheers, J
    1022 has silver 911 on dash and 5 pleats on the seats
    Membership #3255
    301022
    revivem.co.nz
  5. #525
    May 2014
    Netherlands
    Txs Ivan, see also PM.
    member 2971 Jacques
    911 March 1965
    912 April 1965
    911 May 1965
  6. #526
    Senior Member earlyaircooled's Avatar
    Jun 2008
    Portland, OR
    door latch receivers on my 717 car, note they are held on with large phillips screws not 6 or 12 point allen heads. The screws are painted black and it looks factory to me
    1975 911S targa , 1989 944 turbo S original paint survivor, 1978 924 track car, 1980 924 m471 sport options
  7. #527
    Jun 2008
    Portland, OR
    door stops
    door stops have threaded inserts not studs sticking out like later ones, and they have an interesting makers mark on them. At some point they switched to a stud sticking out style which would make them easier to mount. Name:  WP_20161228_006.jpg
  8. #528
    Nov 2002
    San Dimas, CA
    Quote Originally Posted by earlyaircooled View Post
    301382 also has similar screws but no traces of black paint.
    Name:  2017-01-08 20.25.17.jpg
    They don't have the typical markings but pozidrive bits fit mine better than Phillips bits. Pozidrives are probably best known for attaching bindings to skis.
    The SWB PET parts catalog [E_911-1_Katalog.pdf] lists two different length screws with the same part numbers: E 999.147.001.02 countersunk-head screw M8 x 35 and E 999.147.001.02 countersunk-head screw M8 x 40. I suspect something as common as a Phillips-head screw wouldn't get an E code.
    The LWB PET parts catalog [E_911-73_Katalog.pdf] lists E 999.147.001.02 countersunk-head screw M8 x 35 and 999.219.008.00 countersunk-head screw M8 x 40. The change probably came somewhere between 1969 and 1973.
    Aase has this 999.219.008.00 which takes an M8 12 point allen bit:
    Prices for 999.219.008.00 countersunk-head screw M8 x 40 run from $ 9.00 to $ 19.00.
    Jim Alton
    Torrance, CA
    Early 911S Registry # 237
    1965 Porsche 911 coupe
    1958 Porsche 356A cabriolet
  9. #529
    Jun 2008
    Portland, OR
    your screws look like they may have been originally chromed. Mine look flat and yours look a little convex to me. And your right they do look like pozidrives that were used to attach bindings to skiis.
  10. #530
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    have seen both versions..mostly the flat ones on early cars..never with black paint
  1. FS: Very early 4 screw dash top 1964 - 1965
    By IAA1963 in forum For Sale: 911 Parts
    Last Post: 12-29-2019, 09:11 AM
  2. Replies: 29
    Last Post: 11-23-2019, 04:41 PM
  3. Replies: 142
    Last Post: 10-22-2016, 05:46 AM
  4. Early heat exchangers 1964/1965
    By Milou in forum Technical Info
    Last Post: 01-14-2014, 10:53 AM
  5. Early 1964 tach and 1965 speedo
    By ixxifan in forum General Info
    Last Post: 06-15-2010, 12:24 PM
