Thread: First engine drop
    Jan 2013
    Montreal
    First engine drop
    Well, got around to dropping the engine for the first time this weekend. Went well, took about four hours with the speedometer cable being the only casualty, forgot to disconnect it and when the transmission dropped it stretched. Glad to see they aren't too pricy. I pulled the engine to clean it up and check the chain tensioners while it's out, I'll post about that in this thread shortly.
Size:  65.7 KBName:  image.jpg
    1968 911T R.O.W. / 68S engine.
    Senior Member Merv's Avatar
    Jan 2013
    Queensland, Australia
    Well done Norm. It is always stressful first time, but in reality quite easy. I did the same recently. Made a comprehensive list of things to do, worked through that carefully, and an hour later, all done. Re-installation was really quick and 30 mins later the motor was running.
    Merv
    Member # 2633
    Cars:
    Porsche '68 - 911N (Sold)
    Porsche 356B (T-6) S Coupe
    Porsche 2010 Gen.2 Boxster S
    Jan 2013
    Montreal
    One of the reasons for dropping the engine was the tensioners. I was pleasantly surprised to see this. I think these are the later style tensioners with the lock collars although I believe the collars are set too low. Can anyone comment on these and the ramps, wondering if these are the newer style ones.
Size:  87.8 KBName:  image.jpg
    Aug 2007
    Phila Pa. area
    Take a look at your blue safety collars. They look like they may be sitting on the tensioner, there should be some clearance between them and the tensioner, I forget how much. Maybe its the angle of the picture and there is some clearance ?
    Mike
    The clearance should be about .100", 2.5mm. But as the tensioners hammer those collars move. Your ramps need a complete update. Left one is rubber. And the idler chain sprockets look like the non bushed early style. It never ends, I would do ramps, idler arms, idler axles, sprockets and later tensioners to match the updated idler arms. Gled PS What year is the engine.
    Aug 2012
    France
    Hi, were you alone to drop the engine ?
    Xavier
    O-G 26 - Early911S 2407
    Jan 2013
    Montreal
    Quote Originally Posted by brakekiller View Post
    Xavier
    Me and my 15 year old son, we did get two extra people to help us lift it on the stand though.
    Jan 2013
    Montreal
    Gled, what's the difference between these and later tensioners, I thought these were 930 style. I do not want to go the hydraulic route as this engine will only see a few thousand miles per year. Engine is a 68 S
  1. Replies: 1
    Last Post: 01-10-2013, 02:37 PM
  2. FS: Drop Forged Steel 12 X 13
    By typ901 in forum For Sale: 911 Parts
    Last Post: 07-19-2012, 09:12 AM
  3. SWB front ARB drop links
    By tomkirkcis in forum General Info
    Last Post: 09-23-2009, 05:14 PM
  4. rear end drop - help
    By red67 in forum Technical Info
    Last Post: 04-21-2008, 01:18 PM
