Thread: Ignition Tumbler Removal
    Oct 2012
    ON
    Question Ignition Tumbler Removal
    I am interested in hearing from anyone that has removed the tumbler from the ignition. How do you remove the tiny pin holding the tumbler in place? I would rather not drill it out if there is any other way. Thanks.
    Member #2666
    Drilling is your only option but not for newbies. Get a locksmith to do it. Very easy to destroy your lock
    Oct 2012
    ON
    Thanks David. I suspected as much. I was just hoping that someone out there had come up with some ingenious way of removing the pin without destroying it.
    Perhaps once it is drilled out it can be tapped to take a tiny screw so it can be removed again in the future?
    Member #2666
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    —Juan Manuel Fangio[48]
    ”What would PORSCHE do”
  1. How to disassemble glove box lock/tumbler?
    By bob tilton in forum Technical Info
    Last Post: 05-28-2021, 08:40 AM
  2. WTB: Old Porsche lock tumbler pins
    By bford in forum For Sale: 911 Parts
    Last Post: 12-16-2013, 05:53 PM
  3. Ignition Tumbler - Will it Stay Fixed
    By lwalwa in forum Technical Info
    Last Post: 09-19-2011, 09:06 AM
  4. ignition lock removal problem
    By RSTarga in forum Technical Info
    Last Post: 12-31-2010, 05:06 PM
  5. WTB: 65-67 Ign. Tumbler&Switch
    Last Post: 12-18-2008, 07:24 PM
