Thread: '71 2.2 in a '66, will the engine tin fit properly?
    Senior Member eaton's Avatar
    Nov 2009
    DC/Montana
    Newbie question here. As I go back and forth on painting or powder coating the tin for the 1971 2.2 I'm getting ready to put in my '66, I realized I should ask a more important question: Will the tin fit? Is engine tin interchangeable, or would the '71 tin/carrier not fit properly in the '66 ?
    The MFI tin is different than the carb tin. I mean, the external dimensions are the same, but things like the holes for the throttle linkage are probably in the wrong place, the MFI tin has some big tubes to carry the preheat for the thermostat, etc.
    Aug 2009
    SF Bay Area
    Quote Originally Posted by eaton View Post
    for all intents and purposes, yes, it will fit and the sheet metal is interchangeable with a few minor "adjustments". If you are dropping a 71 complete engine in your 66 it will fit perfectly. If you are putting the 66 engine tin on the 2.2 your will need to trim a couple of areas.
    Jim
  1. Replies: 8
    Last Post: 09-01-2012, 05:47 PM
  2. Fleebay Engine: 1968 Porsche 911S Engine 901/02 Weber IDS 40 Carbs 911 S Motor
    By Doc72 in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 08-31-2012, 07:09 AM
  3. Replies: 23
    Last Post: 08-30-2012, 06:01 PM
  4. Replies: 3
    Last Post: 11-21-2011, 02:58 AM
  5. Replies: 33
    Last Post: 11-02-2005, 03:13 PM
Tags for this Thread
