Results 1 to 10 of 14
Thread: Trim help needed please
    Can anyone help me with a part number/place to buy for the plastic trim that pushes into the back of the anodised rear bumper trims on a 73 car please.
    My part book shows the part seperately in the diagram but then lumps it with the alloy trim and rubber insert for a part number which surely cannot be correct.
    Thanks in anticipation.
    Clyde Boyer
    Early S Registry Member #294
    TYP 901 Register Inc #6
    I've just bought two bumpers and they came with them in a separate bag but they were all part of the full kit not an individual part that I know of.
    Porsche parts or reproductions
    Clyde Boyer
    Repro but to be completely honest you can't tell the difference.
    I had my originals re anodised as most people indicated the curves were all wrong on the repros and they don't fit properly so I will be interested to hear
    back from you once you fit them.
    It cost less, they look brand new and I know for sure they fit, I just have to find some plastic trim and I am all good.
    Clyde Boyer
    Jul 2011
    Chicago Area
    Is this what you are looking for? http://www.stoddard.com/911-1965-75/...wide-deco.html
    Mike Fitton # 2071
    2018 911S Carrera White
    Quote Originally Posted by mfitton View Post
    No I think thats for side deco which is a different
    Profile but thanks for looking
    Clyde Boyer
    Clyde, I agree with you in that it seems the repro beading under the deco has a wider edge showing that the original. I will soon need to chase this, as like you, I get deco re-anodized so I know it will fit. Also possibility Int. Mercantile may have that as a 356 part for example, don't know, just wondering?
    Yes your right, it is much thicker all round and the sill deco doesn't want to sit flush like it should.
    I also think in its correct form that the side deco and the rear bumper trim I am chasing are a different profile but may have to re check that, I am starting to 2nd guess myself.
    Clyde Boyer
    Definately a different piece of plastic than is used on the sill trim
    Clyde Boyer
  1. dash trim help needed
    By vtrich in forum General Info
    Last Post: 10-31-2012, 11:30 AM
  2. Replies: 2
    Last Post: 06-06-2012, 02:16 PM
  3. New dash alloy trim needed
    By BOYER73S in forum General Info
    Last Post: 02-21-2011, 05:24 PM
