Maybe a Davep question....
What is the specific engine designation and application for the three 72-73 MFI pumps...013, 019, 021
Thanks in advance
Speedo
Thanks in advance
Speedo
registry# 1283
edit: I was wrong, see below.
I believe the full listing is as follows along with the corresponding Porsche part numbers
911T = 0408 126 015 (US only up to 1973.5) Part# 911 110 251 00
911E = 0408 126 014 Part# 911 110 252 00
911S = 0408 126 013 (ROW) Part# 911 253 00
911S = 0408 126 021 (US) Part# not known
911 Carrera = 0408 126 019 Part# 911 110 254 00
Hope this helps.
Mark
Early S #2826
Garage:
'73 E (2.7RS replica) - sold
'94 968 Clubsport M030 - sold
'67 250SE Cabriolet - sold
'71 Skyline GT - sold
'69 911S - sold
'73 911T/RS
From Check Measure Adjust:
Thanks guys. Be interesting to trace the history of how a euro 013 ever made it to the states.
Speedo
registry# 1283
My US delivered 2.4S also has an 013 pump.
I've always chalked it up to the rule of "no absolutes from the Porsche factory"
Kent
E911SR & RGRUPPE
'73 S Coupe #306
I've run into the same thing...... I've always chalked it up to about the first half of 2.4S production were 013's (dark looking bodies) and the last half were 021's (shinny looking bodies). My April build '73 came with a 021.......... I've only seen 2.7 Carrera's with 019's. (either dark or shinny looking bodies)My US delivered 2.4S also has an 013 pump.
Maybe the 013/021 question should be 'late vs early' production... ?
As stated before here, and just to further confuse things:
When I had Gus rebuild my 021 pump to RS spec, it came back with a 019 plate....
Less confusing for him, he did the same to mine
My 73S Euro (Italy) 11/72 build, has an full Alu alloy pump 013 with a date code of 10/72. Gled
Well there'ya go .... That blows the crap out of my theory..........My 73S Euro (Italy) 11/72 build, has an full Alu alloy pump 013 with a date code of 10/72. Gled
Thanks for the data point Gordon......
