Thread: Can I test my tacho ?
    Senior Member majordad's Avatar
    Dec 2012
    Cork , Ireland
    I've a number of circa 1972/3 tachos and am unsure which if any are working. Is there any way I can test them off the car or wired up to the car to find which work ?
    Oct 2010
    Florida
    Here's an article that I wrote a few months ago. It's all about vintage gauges. Seattle Speedometer sees more customer inflicted damage than they do normal problems. They suggest you call them before you do anything. The call is free. You don't want to create a bigger problem than you already have.
    Richard Newton
    Quote Originally Posted by majordad View Post
    72/73 tachos with a "C" connection on the back run off an 11 volt square wave with a 63% duty cycle. You can use a signal generator, a 555 timer, anything that generates a square wave.
    Dec 2012
    Cork , Ireland
    Thanks guys. I'm in Ireland so not feasible to send them to USA for testing. I'll get a good auto electrician here to do as you say.
  1. 10K tacho
    By one-two in forum For Sale: 911 Parts
    Last Post: 09-02-2012, 10:46 AM
  2. 10,000 rpm Tacho
    By mrg3.6 in forum General Info
    Last Post: 05-07-2008, 01:01 PM
  3. cost of compression test/leakdown test?
    By aknatar in forum General Info
    Last Post: 06-07-2007, 09:22 AM
  4. 911 R tacho
    By ydderf911 in forum Technical Info
    Last Post: 11-28-2006, 07:25 AM
