Thread: '67 chain ramp installation difficulties
    Nov 2006
    S. F. Bay Area
    1967...Installed chain housings, and trying to get last 2 ramps on (the newer, black hard-plastic ones) ….but they don't go. I'd tap them with a soft hammer but I don't want to break them.
    Any ideas? Tips? Thanks
    Brian
    S Reg #1032
    Yep, you gotta tap them on, don't like it either. Grease the pin and pin hole in the guide block, set it up against the pin, I lay a compost (deadblow) mallet against the rail and then tap that smartly with another mallet (so the blow isn't directly on the block but rather transferred from the mallet.
    Nov 2006
    S. F. Bay Area
    Thanks, Ed…I'll take a ……..whack….at it.
    Brian
    S Reg #1032
    Nov 2006
    S. F. Bay Area
    Update: One minute in microwave on 'high' is enough to soften ever-so-slightly. Thus, they pop right on.
    Brian
    S Reg #1032
  1. fender installation
    By maverick in forum Technical Info
    Last Post: 04-04-2015, 03:10 AM
  2. H1 installation
    By frankmar in forum Technical Info
    Last Post: 11-24-2013, 07:00 AM
  3. Roll bar installation
    By Bob Harriman in forum Technical Info
    Last Post: 12-12-2012, 08:35 PM
  4. Antenna installation
    By cmcfaul in forum Technical Info
    Last Post: 12-15-2008, 01:12 PM
  5. carpet installation
    By pu911rsr in forum Technical Info
    Last Post: 09-12-2005, 09:05 AM
