Thread: Help needed : how to connect a 10000rpm tachometer
    Jul 2009
    Bordeaux FRANCE
    I need the help of the experts:
    I'm facing connectivity problem with my tachometer which does not work properly.
    twin plug distributor with points, 2 HKZ CDI boxes, 2 Bosch coils
    normally the transistorised tachometer operates on the pulse count principle and shows engine speed in revolution per minute (rpm)
    could you please explain how to connect the different wires in order to get this tacho showing the correct rpm.
    thank you in advance.
    Regards from France.
    connect a wire from the points terminal on the side of the distributor that triggers the BHKZ to the tach.
    The BHKZ contains a "pull-up" resistor to power the tacho drive circuit.
    you only need to wire up one, I assume your plugs fire simultaneously.
    your tach should be a later (10.70 onward) version with a "C" on the terminal on the back. if you have /1, you need some kind of a tach adapter
    hope this helps. do NOT touch anything to the "A" terminal on the BHKZ! (High Voltage ! )
    Jul 2009
    Bordeaux FRANCE
    Thank you for your explanation, I found your thread regarding tachometer wiring and erratic tacho.
    all is clear, I can now try to solve this wiring issue.
    regards
  1. Should the air intake hose for 1972 911T connect to anything?
    By SpawnyWhippet in forum Technical Info
    Last Post: 12-31-2013, 08:03 PM
  2. Replies: 9
    Last Post: 03-24-2013, 12:48 PM
  3. R Gruppe re connect help
    By geneulm in forum General Info
    Last Post: 01-16-2012, 05:56 PM
  4. Which battery to connect for a jump start?
    By nickR in forum Technical Info
    Last Post: 01-20-2007, 10:09 AM
  5. How to connect an oil line?
    Last Post: 05-31-2006, 05:47 PM
