Results 1 to 9 of 9
Thread: 100 Liter Fuel Tank Install
    Dec 2008
    Woodland Hills, CA
    I thought I would share my 100 Liter Tank install as well the spare tire strap kit.
    Here I set the tank in place for the test fit.
    Next it shows the tank clamped down and the straps mounted.
    Next pics show the strap mounts. I just got the steel wheel back from the powder coater. Just waiting for the tire to arrive and I will post the final pic.
    Senior Member gregbus's Avatar
    Feb 2011
    Lake Tapps, WA
    This path sure rings a bell I've been going through many of the same things. I worked with John Gausden (advtracing) to get a spare strap made for it. He even got the black webbing for it to go along with the black leather strap. I sent the spare down to Harvey to have him work some of his magic on the wheel itself. I have a set of 5 Avon tires coming in for it. Home stretch now! Like you...more pics to come.
    Greg
    “Whether you think you can, or you think you can't...you're right.” - Henry Ford
    Sep 2008
    Auckland , New Zealand
    looking good
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Dec 2008
    Woodland Hills, CA
    Here is John's (Advtracing) strap kit with the spare tire installed. Still waiting for the sending unit from Specialty Cars to complete the project.
    Sep 2008
    looks good , what feed back do you have for me , anything to alter / change
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Dec 2008
    Woodland Hills, CA
    You might want to consider providing a template for the location of the strap mounts. It's quite tedious centering the setup with the correct angles for the brackets. You only get one shot when drilling the holes for the brackets. Very nice setup though John.
    I chose to use nuts on the bottom of the bracket screws with blue locktite. If the nuts come loose, you will have to move the tank to access the nuts...so I used nylock nuts with flat and lock washers, and blue locktite. I could have used sheet metal screws, but I feared they would keep coming loose from the tension placed on the straps and we all now what the end result is of having to keep retightening a sheet metal screw.
    I used a 185/70 Vredestein for my spare tire selection.
    Sep 2008
    Good plan , was going to make a template for the items , but due to there being no 100 and 110ltr tanks in nz i have nothing to for one off for these sizes . i will make one for the other sizes .
    John Gausden
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    I Can See the Hole (sorta) . . .
    . . . but what happened to the sender? . . .
    Specialty Cars fuel Gauge
    "Waiting for......"
    Be prepared to pull your fuel gauge instrument, and have it re-calibrated for the taller sending unit. I just sent both off to Hartmut at Palo Alto for the fix. The Specialty Cars piece is VERY nice, but the calibration thing was a bit of a surprise.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  1. 100 Liter Fuel Tank Install
    By gsjohnson in forum General Info
    Last Post: 03-07-2014, 05:57 PM
  2. 120 liter fuel tank question
    By cscrogham in forum General Info
    Last Post: 08-04-2013, 02:35 AM
  3. FS - 85 Liter Plastic Fuel Tank for 73 RS
    By Zuluracerx in forum For Sale: 911 Parts
    Last Post: 08-12-2011, 07:02 PM
  4. FS: 81 liter plastic fuel tank from 72 S
    By philvb in forum For Sale: 911 Parts
    Last Post: 04-10-2009, 02:51 PM
  5. WTB: 100 or 110 liter fuel tank for '69 911
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 11-01-2007, 03:08 PM
