Thread: Newb questions - Airbox & Ducktail
    Greetings.
    1st post---newb questions:
    1) I have read that airbox pop-off valve is recommended for Pre-84 cars, but then only listed for CIS engine. Is the popoff not needed for MFI engines (e.g. 73 RS 911/83)?
    2) Are all original 73/74 ducktails steel/fiberglass/or combo---e.g. how/where to check for originality using magnet?
    [Didn't find #1 in a search]
    Keith
    May 2005
    Oroville, CA
    Pop off valves are for CIS only...so 73.5 could use them but for some reason we didn't have as much problem with the 73.5s as the 74>. I would put one on though if I ever owned a CIS again.
    The original duck tail frames are either steel or aluminum. That alone doesn't verify the originality because from 73 you could buy a duck tail made in California with a steel frame...
    You have to look for other quirks.....
    H
    Lightbulb
    What Harvey said ....... plus this old thread might also help:
    http://www.early911sregistry.org/for...cktail-details
    Cheers
  1. Newb with some Newb questions & a few problems
    By 71911E in forum Technical Info
    Last Post: 11-25-2013, 07:47 PM
  2. WTB..... 72'-73' MFI AirBox
    By TB73 in forum For Sale: 911 Parts
    Last Post: 03-24-2011, 08:33 AM
  3. FS 911 73.5 CIS Airbox
    By gled49 in forum For Sale: 911 Parts
    Last Post: 04-25-2010, 09:34 AM
  4. FS: 65-68 airbox; 69-73 airbox base
    Last Post: 07-06-2008, 07:57 AM
