I'm getting ready to install this engine and realized I'm missing an important few bits -- the two bolts that connect the top of the transmission to the engine. Not listed on Pelican. I could also use the nuts and washers that fit the bolts on the bottom, although I suppose I could get those at the hardware store. The engine is a 1970. Transmission is 1966, if that matters.
Thanks, Joe
